axle cut and respline
Posted 05 June 2006 - 08:54 PM
any probs with going ahead and using it without and if not what is the recommended treatment?
#2 _Oldn64_
Posted 09 June 2006 - 02:08 AM
Posted 09 June 2006 - 02:27 AM
I dont want to name names but it was done at a very rep shop.
Posted 10 June 2006 - 01:05 PM
common guys anyboby had problems with their axles in 9" or B/W diff conversion or is everybody running billet axles.
#5 _Oldn64_
Posted 10 June 2006 - 02:28 PM
PS: PM Comming
Posted 10 June 2006 - 02:41 PM
i may be asking the wrong question but im after a treatment that goes skin deep to protect the spline from damage.The bw axles are not a cut spline they are a presed spline. so they compress the steel to make the splines therefopre no heat treatment is required as the axles have not had there splines cut. ie no heat.
PS: PM Comming
is this process called hardening, not heat treatment.
then again i really dont know and may be machined axles need both treatments.
may be they dont need anything as ive been told.
Edited by ALX76, 10 June 2006 - 02:44 PM.
#7 _Oldn64_
Posted 10 June 2006 - 02:45 PM
Posted 12 June 2006 - 08:40 PM
Youlle be sweet for years, of course depending on how you abuse it.
