I've seen these RSP ones, however I'm not sure if they suit LH? Also do these items include the motor/pump assy???
http://www.rarespare...product=7434262
Edited by hanra, 26 May 2012 - 09:19 PM.
Posted 26 May 2012 - 09:19 PM
Posted 26 May 2012 - 09:30 PM
Edited by LHSL, 26 May 2012 - 09:31 PM.
Posted 26 May 2012 - 09:45 PM
Posted 27 May 2012 - 04:23 AM
rare sparesA pic would be awesome mate!!!!! Wow, $50 and no motor.... Can you buy motors to suit??
Posted 27 May 2012 - 08:01 AM
Posted 27 May 2012 - 08:52 AM
pm sentAre you aware if an original pump would fit into the aftermarket washer bottle?? I don't like my chances of finding a decent nic washer bottle 2nd hand, but I could probably find a pump a bit easier?
Posted 27 May 2012 - 09:18 AM
Edited by walpolla, 27 May 2012 - 09:20 AM.
Posted 27 May 2012 - 09:31 AM
Posted 27 May 2012 - 10:05 AM
Posted 27 May 2012 - 05:38 PM
Posted 27 May 2012 - 07:40 PM
Posted 27 May 2012 - 08:46 PM
Posted 27 May 2012 - 08:57 PM
Posted 27 May 2012 - 10:05 PM
It is a while since I set mine up Brad, but I think I had to very slightly enlarge the hole in the new bottle, and then used the coarse screw on the original pump to sort of cut a thread into the bigger hole. Once that was done, the old nylon nut from inside and washer was screwed down, and the rest is history.
There must be squillions of Holden washer pumps around, just find one that works, give it a Dulux overhaul and you are set.
Thats all I did. If it ai'nt broke - do'nt fix it. ( which I must do on the power plug to the washer pump, it keeps falling apart - hence the blue cable tie around it)
regards,Rod
Posted 27 May 2012 - 10:44 PM
Super Cheap actually used to sell a motor as a GMH replacement, had the windscreen washer as per original, for about $12
Don't know if they still do, this was a couple of years ago when I did this research
Posted 27 May 2012 - 10:50 PM
Posted 27 May 2012 - 11:42 PM
To easy mate. My car was supplied to me without a bottle at all... And as such, Ive never physically seen one. Once I get my hands on one Im sure Ill figure things out!!!
Judging from Pics Ive looked at and they way my wiring harness sits, it appears that the pump has a short wiring loom coming from it with the plug on the end? Is this short loom fixed internally into the motor or is there external terminals with another plug?
Posted 28 May 2012 - 09:41 AM
Ive asked for a few more pics of this Holden one:
http://www.ebay.com....=item416226592c
Posted 28 May 2012 - 10:05 AM
Posted 28 May 2012 - 10:46 AM
Yeah thats the problem, no wrecks up this way. Thanks mate.
Posted 28 May 2012 - 11:35 AM
Posted 28 May 2012 - 12:01 PM
Posted 28 May 2012 - 02:47 PM
Posted 28 May 2012 - 03:14 PM
Posted 28 May 2012 - 09:00 PM
