253 crank in 308??
9 replies to this topic
#1 _toddy_
_toddy_
Posted 06 June 2006 - 09:12 PM
Hey Guys I have read in a few posts on here that you can put a 253 crank in a 308 block, thus creating a stroker...
My questions are
Can this really be done?
How can it be done? (what is needed?)
Will it be reliable?
Is it worth doing?
Comments will be greatly appreciated as I have a 308 which needs a new crank, and a 253 which is ok but I dont really want another one. Hence the questions
#2 makka
makka
    A m��se once bit my sister
  • 3,559 posts
  • Name:Cohen
Posted 06 June 2006 - 09:23 PM
you wont gain anything from doing that, other than a very unbalanced engine. they have the same stroke.
you could get the 253 crank offset ground then you have a 330 odd cube stroker build on your hands.......
#3 _[BOTTLEDUP]_
_[BOTTLEDUP]_
Posted 06 June 2006 - 10:56 PM
As mentioned by Makka you use an offset ground 253 crank with a SBC small journal rod and a 350 Chev piston (or machined down 308) to create a 328ci stroker.
#4 _JBM_
_JBM_
Posted 07 June 2006 - 12:43 AM
You need to have light pistons because the counterbalances on the 253 crank are smaller than the 308s. Heavier pistons will put everything out of balance and vibrate excessively.
James
#5 TerrA LX
Posted 07 June 2006 - 12:57 AM
One guy that does the 253 crank thing actually gets a crank specially cast with extra webs added at the centre.
#6 _toddy_
_toddy_
Posted 07 June 2006 - 06:31 PM
So in all reality I will be better off if I go for the regrind on the 308 crank and maybe offset grind on that one?
#7 _gtr161s_
_gtr161s_
Posted 09 June 2006 - 03:18 PM
Try pro stroke in vic, they do all sorts of combo's like what your asking.i dont have there number but should be easy to find
#8 _Herne_
_Herne_
Posted 09 June 2006 - 03:32 PM
It is my understanding that rebalancing a 253 crank for a 308 motor is rather costly and thus somewhat inhibiting! That is it defeats the purpose when considered dollar for dollar.
Which is a shame as I have plenty of 253 bits lol.
Herne
#9 makka
makka
  • 3,559 posts
  • Name:Cohen
Posted 09 June 2006 - 03:56 PM
pro stroke
most of the time when you get an ofset grind crank its a 253 one, because the chev pistons and rods used in a 330 stroker are lighter than 308 pistons and rods I think.
Edited by makka, 09 June 2006 - 03:57 PM.
#10 FastEHHolden
FastEHHolden
    Steptoe
  • 5,114 posts
Posted 09 June 2006 - 04:00 PM
almost..that hyphen gets me quite often
www.pro-stroke.com.au
