Hi guys had enough of blowing up bangos and 4 spd boxes just got a celica 5spd and a bell housing from dellows was wondering the best way to go got a spigot for celica to holden ??
Celica 5spd conversion from all aussie
_troy_
, Jun 07 2006 05:05 PM
5 replies to this topic
#1 _troy_
Posted 07 June 2006 - 05:05 PM
Posted 07 June 2006 - 05:37 PM
if your talking about the bush, best to get one from dellows as they make this especially for this conversion. not sure if the holden one is the same but i wouldnt risk not calling them first.
definatly install one especially if going from auto as the rear of the crank id different to manual.
#3 _troy_
Posted 07 June 2006 - 07:41 PM
Yea i have 2 bushes to suit the crank ,was wondering which speedo cable to use the celica 5spd or the m20 4 speed cable?
Posted 07 June 2006 - 07:52 PM
they do the same for the cable, each u have will only fit one end.
#5 _Pedrobully_
Posted 09 June 2006 - 10:20 PM
Have a look at Rare Spares for the spedo cable, they do the convertion one to suit Toyota 5sp to Torana Spedo.
You could have a look at XTREME street wise clutches. www.xclutch.com.au
they did a full clutch to suit Toyota 5sp Steel to holden red 202 with clutch plate spline to suit the 5 spd, new thrust bearing, clutch pressure plate befed up and spigut bearing to suit, delivered to Darwin for under $300.
#6 _Oldn64_
Posted 10 June 2006 - 02:57 AM
I used to make my own one it does not take too much, just start with teh holden one and fit the toyota speedo screw plate on teh end... A lighter is your secret.they do the same for the cable, each u have will only fit one end.
PS: This is how I put a celica box in a Gazelle many moons ago.
