Celica 5spd to LC 202 conversion
3 replies to this topic
#1 _troy_
_troy_
Posted 07 June 2006 - 05:09 PM
Hi guys had a gutsfull of blowing up aussie 4spd boxes blown 3 up this year so far bought a whole celica for its gearbox ,aquired a dellows bell housing and bought the right spiggot bearing getting the tail shaft cut to fit.Which speedo cable do u use the celica or aussie 4spd ?? :rockon:
#2 _draglc_
_draglc_
Posted 07 June 2006 - 08:17 PM
Cant use either..
you can buy a speedo cable to suit from dellow for $80+ postage.
A1
#3 _munro_
_munro_
Posted 08 June 2006 - 10:36 PM
i used one out of an early corolla around '76
the speedo is out but it's caused through gearing ratios
work out what rpm your doing at 100km/h in 4th gear with the aussie
do the same with the celica box then divide whatever your speedo is reading by 10
ie: if your speedo is reading 45mph then for every 4.5mph on your speedo your doing 10km/h
hope that helps :spoton: tom
#4 _troy_
_troy_
Posted 10 June 2006 - 09:31 PM
Thanks tom rung dellowsfor a cable $85
