g'day all.
ive decided i should go to HQ stud pattern on the torrie so i can have the better brakes.
i know this is probually asked to many times before but how do i swap to HQ and what do i need?
would it be best to get a HQ sub frame brakes and all or just the disc's and calpiers?
also are there any diff between HQ and newer like HJ-WB?
cheers gump
stud patteen
Gump
, Jun 07 2006 10:18 PM
8 replies to this topic
Posted 07 June 2006 - 10:18 PM
Posted 08 June 2006 - 01:54 PM
you will need the stub axles, discs and calipers.
the earlier HQ/HJ brakes are better apparently, thats what I have I think.
what diff are you planning on running?
Posted 08 June 2006 - 03:37 PM
9 inch hopefully
Posted 08 June 2006 - 04:45 PM
then just get them to set it up for hq pattern
Posted 08 June 2006 - 05:35 PM
Yeah i agree with makka... u need the stub axles, discs and calipers. then just get a 9inch and get hte rear with HQ studpattern axles
#6 _moot_
Posted 08 June 2006 - 08:31 PM
if you use hq rear discs,how do you go with handbrake cables? any tricks?
also what master cylinder would suit? i need one without the propprtioning valve.
Posted 08 June 2006 - 10:10 PM
i hve A9X/HZ rear discs on mine. Im running a standard mc with the prop valve. I got the standard LH cable to fit, but its not the best
Posted 10 June 2006 - 04:43 AM
hey makka
standard HZ reardisc brakes fit well. wonting to fit them ,have a 9 inch with HQ stud pattern it has drum brakkes (10.5 ) be a blast if they fit
Posted 10 June 2006 - 03:32 PM
they fitted perfectly, mainly because they were on my diff from the factory, I cant see why they wouldnt fit on your car though. Unless your diff housing ends are different to mine.
