Crank gear
#1 _lxhatch_jim_
Posted 09 June 2006 - 09:42 AM
There has been a full scale attack with large screw drivers trying to lever it off but to no avail. I was contemplating a cold chisel or a butane gun to heat it up.
Any suggestions would be much appreciated.
Jim
Posted 09 June 2006 - 10:49 AM
1) has it got 2 threaded holes in it? if so you can use the harmonic balancer puller to get it off.
2) Use a 2 jaw puller and maybe a spreader plate if you can't get onto it properly.
Heat will help in both cases but don't go mad.
When it comes time to install the new gear either heat it in the oven or boil it in oil and use a piece of pipe over the nose of the crank to drive it on.
Posted 09 June 2006 - 11:14 AM
#4 _Oldn64_
Posted 09 June 2006 - 12:32 PM
Secondly are you trying to remove the cam shaft? If so there are two phillips head screws that hold the cam in on a thrust plate. you need to remove these screws before the cam shaft will dislodge, the other thing is all lifters, fuel pump and oil pump must be removed for teh cam to come out. Good luck.
Is the cam timing gear a fibre one or a metal one? Make sure that when removing the lifters that they go back into the same positions, otherwise you will find the cam will wave goodbye in a short period of time.
#5 _lxhatch_jim_
Posted 09 June 2006 - 02:13 PM
The crank is on the engine which is in the car hence I can't use my press.
I've got a puller but there aren't any holes in the crank gear so no harmonic balancer puller. I'm not too keen on drilling holes and tapping a new thread.
As for the gear on the engine, it's steel. The ones I'm using with the new cam are alloy, which is why I'm changing the crank gear to begin with.
I plan to use loctite and an impact screwdriver to put the thrust plate screws back in securely.
All I'm really after are techniques from people that have done it before, especially if it didn't "just come off with a screwdriver".
Jim
#6 _Oldn64_
Posted 09 June 2006 - 02:35 PM
Posted 09 June 2006 - 03:38 PM
Where do you come from?
#8 _lxhatch_jim_
Posted 09 June 2006 - 04:17 PM
Jim
Posted 09 June 2006 - 05:05 PM
Can't borrow a 2 jaw puller?
I've never seen alloy straight cut cam gear.
#10 _efi-202_
Posted 09 June 2006 - 05:11 PM
#11 _Oldn64_
Posted 09 June 2006 - 05:17 PM
I am not sure a puller will do this. simple reason being is that this is a interferance fit (and a bloddy tight one. If not right it will walk off and thisis not good for anyone!$30 will buy that puller..its in brissy
Posted 09 June 2006 - 09:42 PM
I took my crank and cam down to the local engine builders and got the to pull my old gears off and fit my new straight cuts
Loui
#13 _lxhatch_jim_
Posted 10 June 2006 - 05:42 PM
Now that wasn't that hard was it?
Jim
#14 _MAWLER_
Posted 10 June 2006 - 06:43 PM
Its off now so thats the main thing.
Peace
Posted 11 June 2006 - 01:11 AM
I hope this makes you feel better
Edited by rodomo, 11 June 2006 - 01:19 AM.
#16 _high_rpm_
Posted 11 June 2006 - 01:22 AM
