gday
ive got a nine inch with HQ std pattern and want to fit disc brakes to it. would HZ WB rear disc brakes fit to it any help would be great cheers
HZ<WB rear disc brakes
red1a
, Jun 10 2006 01:41 AM
8 replies to this topic
Posted 10 June 2006 - 01:41 AM
#2 _Oldn64_
Posted 10 June 2006 - 02:44 AM
If you wish to assist your search then commodore discs and calipers will fit. This also means that you can upgrade to bigger brakes again. But word of warnign while runnign the disc on a hq/chev pattern it is dangerous to run a commodore rim on a hq/chev pattern. You will shear the studs off and loose the wheel. The commodore and HQ pattern is different. Not by much but it still fatigues the studs.
Posted 10 June 2006 - 03:04 AM
is there no go with HZ Wb rear disc brakes
#4 _Oldn64_
Posted 10 June 2006 - 03:32 AM
No not that it is just to find them is a little thin on teh ground as all teh HQ-HZ guys want them.
Posted 10 June 2006 - 03:41 AM
I can get a set , do they fit
#6 _Oldn64_
Posted 10 June 2006 - 03:46 AM
I believe they do but it is always good to check first. I think there is too types of bearing sizes in teh 9 inch range and depending on your diff will depend on teh sizing.
But as long as you have hq pattern then the rotor will goover the axle just not sure on the axle bearing plate..
Posted 10 June 2006 - 04:26 AM
wouldnt the teh be a standard works with what diff you have when its made for a LH torana 9 inch set up for HQ stud pattern
#8 _Oldn64_
Posted 10 June 2006 - 04:27 AM
Depends on teh diff housing....
#9 _Hotrodder_
Posted 10 June 2006 - 09:29 AM
Easiest conversion is use the commodore disc which will fit over the HQ studs, and a nissan pintara caliper which has the handbrake assy in the caliper. They look very similar to the VN V8 (and VL turbo) calipers. make an adapter from 10mm plate which welds onto the diff housing, job done. Ive done a few of them now, cheap and simple to do.
If you need more details lemme know.
