AP Racing 4 spot's, Need Help!
#1 _Romper_
Posted 06 September 2012 - 07:09 PM
They are to suit VT-VZ Commodore if that's any help, i want to piss off the bigger rotor's and run smaller 290-300mm rotors as i want to run 15 inch front runners or similar...
Want to fit them to an LX....
I've already done a search and found topic's on AP brake conversion's on Torana's etc, so dont ask me to search cos it doesn't say anything about where to locate the model number on the caliper, i've searched and searched with no luck...
Any help will be greatly appreciated...
#2 _Bomber Watson_
Posted 06 September 2012 - 07:15 PM
#3 _Romper_
Posted 06 September 2012 - 09:10 PM
Anybody ???
Posted 06 September 2012 - 09:21 PM
They are unlikely to fit behind the wheel anyway
Anyway
The model number is on the bottom of the caliper
#5 _Romper_
Posted 06 September 2012 - 10:22 PM
Where do i get Stub axles and brackets to bolt up VT-Z brake's to LX Torana Dattoman do you know ??
Posted 06 September 2012 - 11:12 PM
You make your own stuff to fit
If we made it too easy everyone would be doing it
Putting up some caliper pictures might help too
#7 _Romper_
Posted 07 September 2012 - 01:01 AM
http://img219.images...66/photo5cu.jpg
http://img440.images...52/photo6sq.jpg
So has ANYBODY done this actual conversion before or no ??
Posted 07 September 2012 - 09:13 AM
I've used them on about 60 customers cars ranging from Commodores to Mustangs
Usually on a 330mm disc
But yes I have used them on a VT disc to fit under 15" wheels on a Mustang that does abit of targa work
Wheel clearance is going to be your issue
You can see the caliper comes out level with the hub face... so you need a wheel with raised mounting boss and lots of room all the way up to the band or its never going to fit
#9 _Romper_
Posted 07 September 2012 - 06:16 PM
I have emailed Race Brakes Sydney and he said he has a 296mm rotor that would suit that caliper, i'm presuming they are a VT type disc or possibly like a VN-VS V8 type i'm not sure i'll email him back and see, i have also emailed Castlemaine Rod Shop to see if they make a stub axle to go from LX to VT disc. i haven't had a reply as yet....
#10 _the gts_
Posted 08 September 2012 - 02:32 PM
#11 _AGGRSV_
Posted 08 September 2012 - 07:46 PM
#12 _CHOPPER_
Posted 09 September 2012 - 01:36 PM
#13 _Romper_
Posted 09 September 2012 - 02:08 PM
Rod Hadfield do stub axles to suit. These are mine.....
Hey AGGRSV Cheer's mate...
Just a few question's for you...
Are you using AP 4 piston brake's like i posted above in my link's as well or a different caliper ??
How much were the Hadfield Stub axles and what was the fitment and quality like ??
Also what bearing's etc did you use was it all direct bolt up ?? anything need to be modded ??
How much were the 2 peice Disc Rotor's if you dont mind me asking...I'm presuming they are the VT Rotor's in 290'ish mm or are they bigger ??
Have you tried a 15 inch wheel's on there as yet to see if it all clears ??
Also lastly, how is the Track Width ?? Is it wider than standard LX track or wider ??
How do they sit under the car and is there any fouling anywhere ?? As i wont be running Flares so i want to keep it all well within the original gaurds...
Edited by Romper, 09 September 2012 - 02:15 PM.
Posted 09 September 2012 - 04:54 PM
#15 _Romper_
Posted 09 September 2012 - 09:29 PM
Do VT hub's fit directly onto them stub's ??
Posted 10 September 2012 - 09:12 AM
And that depends what your doing with the rest of the suspension geometry as to which stub you want
A std HQ stub drops the car 1.5-2" .. so a 2" dropped one might cause you some issies
The other guys have Torana stubs set up to take Commodore brakes.... but theres still no telling you can make the caliper fit in the little room you have
Its a tight fit with a 330mm disc... let alone a 296mm
#17 _Romper_
Posted 10 September 2012 - 09:22 AM
I will email Stubtech now and see what they have to say..
So the stub's i'm looking for are they drop axle stub's ? or just standard that go from Torana and accept a VT Hub ??
Posted 10 September 2012 - 09:23 PM
Maybe do some measurements and see if the calipers are actually going to go anywhere near it on your standard stubs first
#19 _Romper_
Posted 11 September 2012 - 01:31 AM
Hi,
We do make drop axles (with the correct king pin inclination angle) that will accept the VT mounting hubs that you can purchase and the Commodore calipers with just a minor amount of linishing required on some caliper brackets. We have them in stock at the present time and we send by Australia Post either by registered or normal post (whichever you require).
Please note that CRS is not connected to Hadfields any more, we sold that business eight years ago and CRS no longer produce the axles.
Regards
Rod Hadfield,
[email protected]
www.stubtech.com.au
#20 _Romper_
Posted 11 September 2012 - 01:33 AM
#21 _Romper_
Posted 12 September 2012 - 12:53 AM
He said with the 296x28mm Rotor's and VT brakes there is no rubbing or fouling anywhere, they come with all engineering paperwork etc and the cost is $775 including GST...
I know the AP's and big disc's go directly on VT hub's for certain, so i'm presuming they should also go straight on with minor linishing of the caliper bracket's....( Well here's hoping )
#22
Posted 12 September 2012 - 09:00 AM
Goodluck
Mark
#23
Posted 12 September 2012 - 09:14 AM
Since your going from 328mm down to 296mm
So make them so they don't foul on anything
#24 _Romper_
Posted 12 September 2012 - 02:20 PM
Had this setup and found my car to low for my liking. One thing I did change was the lower bolt on the caliper to an allen key as it just touched the wishbone. But the setup was straight forward, the calipers are in trailing position.
Goodluck
Mark
Hey Mark did you have VT Brakes or AP 4 Piston Brakes with 296mm rotor's ?? Any pic's ??
Did you change them or you still have them on your car...If you changed them, what did you change them too ??
Dattoman, i'm thinking of just using same bracket's but machining down the flat side where the caliper mount's to the bracket, do you think that would work or am i just better off making up some new steel ones....
Cheers guys...
Edited by Romper, 12 September 2012 - 02:29 PM.
#25
Posted 12 September 2012 - 08:50 PM
But can't see your brackets from the pic
