correctly identifying a SS hatchback
_01torana77_
Posted 08 October 2012 - 07:42 PM
I am new member and im looking at buying a LX SS hatchback and was wanting help confirming that the car is genuine please. i did post this info on my intro. ..but i think this is the right spot for it.
Im wanting to know if there is anything else i should be checking for.
here is a list of what i have done so far
car Does Not have original engine (so engine not a concern)
yes is LX8VD77 model
I ran the vin number on torana web vin checker and also rang the motor registery info came back as a sl/r or ss (no sl/r hatchbacks made so assume it is a SS ) ..correct colour...and correct motor size....and year built..
The car has all 3 plates/tags and matching chassis number from what i can work out
i use the LX parts catalogue that i own to cross reference plates (m37758)
month + sequence number = body number
chassis number = saftey compliance plate number
chassis number on end drivers side chasis rail
yes 200km/h dash yellow/orange
i think thats all so far .
Is there anything else to check for please??
And is what i have done so far correct??
They are too expensive to get wrong these days >.<
Tim
Posted 08 October 2012 - 08:06 PM
_01torana77_
Posted 08 October 2012 - 08:11 PM
not identifing whereabouts atm..sorry dont want to be beaten to the punch..so to speak
rts there is defenatily a rear swaybar (yellow-old-missing paint stonechips)
not 100% on the front at this stage
_01torana77_
Posted 08 October 2012 - 08:50 PM
Edited by 01torana77, 08 October 2012 - 08:52 PM.
_j.e.d._
Posted 09 October 2012 - 01:57 AM
http://www.gmh-toran...fying-your-lhx/
As long as the engine prefix says L31 or L32 it'll be a genuine V8 SS - L20 means it was originally a 202.
_01torana77_
Posted 09 October 2012 - 09:43 PM
there are so many links to things take me awhile to navigate properly
_1973bathxu1_
Posted 10 October 2012 - 05:22 AM
the best way ive found out is by the riverts on the id tags they have hexaginal edges if u look closely,
bring a panel beater or someone who knows these toranas
regards aldo
_AquaSLR5000_
Posted 10 October 2012 - 03:04 PM
_AquaSLR5000_
Posted 10 October 2012 - 05:38 PM
Aqua
_imj411_
Posted 10 October 2012 - 06:18 PM
_L31SS HATCH_
Posted 11 October 2012 - 07:52 PM
How'd you go with this mate? Did you clarify everything was as it should be and make the purchase?just to clarify im just trying to identify the chassis/body as a 100% V8 SS.....not a rebadged--fake - or a 4-6 cyl...ect.
Posted 12 October 2012 - 01:43 AM
_01torana77_
Posted 12 October 2012 - 09:21 PM
lol i can just see it now.. Hey m8 just gonna take ya dash apart and have a squiz around.. 'O.O'
what should i be looking at around tail lights ??
inspecting car this weekend
Edited by 01torana77, 12 October 2012 - 09:23 PM.
Posted 12 October 2012 - 09:53 PM
_outer control_
Posted 13 October 2012 - 06:38 AM
SL,s had chrome surrounds around taillight so holes where beenHi everyone . cheers for all the info . by the looks i just have to check behind the dash for matching paint..and rear ashtrays
Posted 13 October 2012 - 08:07 AM
Nope, it's an early thing- my 2/76 has them as well as back of the console! That with the big one in the dash and every bastard has anNot all SS's have ashtrays in the arm rest. It may have been a later thing, my 7/76 has no ash trays. Only ashtray is in the back of the console.
ashtray! Imagine trying to breath in there.
Posted 13 October 2012 - 07:36 PM
_imj411_
Posted 13 October 2012 - 08:18 PM
_cruiza_
Posted 14 October 2012 - 06:48 AM
_01torana77_
Posted 15 October 2012 - 04:29 PM
For those interested ,the car checked out fine .3 tags all matching with correct chassis number,, correct colour overspray behind dash,, rts installed,,no tampering,cutting,welding or panels repaired( ie chassis number),,no chrome tail light surround or any evidence of old rivets /holes,,no rear ashtrays is a mid- late '77 vechile,,200km/h dash,,ect..ect..
They body is in fairly good condition,,its pretty straight ,slight ding in the nose cone and the original guards have been slightly flared(removed factory bottom lip on wheel arches and applyed some filler) only place on car small fridge magnets didnt stick to when applied to newspaper and dragged along body)) ,, hatch hinges only small surface rust and the rear rubber seal for hatch is good also,,just the typical turret seam area just starting to pitt metal 5 cm long both sides,,also car having a bloody towbar attached at some stage obvisouly dont help things in this area,, inner rear 1/4 panels just got some surface rust,, probably wont need replacing..
little bit on smoking and coupes.............. driving a coupe and smoking DONT work well together as air flow usually blows hot ash back in the extended windows and bingo...you now have a nice burn hole in rear seat
anyways yes im now a proud owner of my first lx ss v8 hatch..
yes the sedan got the overnight treatment under the stars last night as i needed a few hours to reorganise and make space in the garage for second torana..and couldnt be bothered at 1am last night
i will be obtaining a 308 HT numbered block from friend for this hatch build..numbers match a lx ss 5ltr hatchback
finally so now the dissision making time .. i initally wanted to get straight into hatch rebuild ..a Full bare metal resto upto show/drive standard..but after talking with friend have decided to at least get sedan back to having topcoat on her.then decide if to keep ,sell or convert into another hatch..
Edited by 01torana77, 15 October 2012 - 04:31 PM.
#21
Posted 15 October 2012 - 05:12 PM
#22
Posted 15 October 2012 - 05:45 PM
#23
_01torana77_
Posted 15 October 2012 - 05:59 PM
Edited by 01torana77, 15 October 2012 - 06:00 PM.
#24
Posted 15 October 2012 - 06:04 PM
http://www.photobucket.com
Edited by hanra, 15 October 2012 - 06:06 PM.
#25
_01torana77_
Posted 15 October 2012 - 06:15 PM
