Cruise Control
_Swampy_
Posted 13 June 2006 - 01:50 PM
Posted 13 June 2006 - 04:13 PM
If this is just the wiring to the speed sensor, run it with the kickdown wire up to the firewall & then come in thru the speedo cable grommet.
Dr Terry.
_Swampy_
Posted 13 June 2006 - 07:07 PM
_Leakey_
Posted 13 June 2006 - 07:29 PM
My neighbour is Command, and has bucketloads of how to's for his install guys.
Maybe he has one I could send to you.
Let me know, preferably PM me.
Cheers, Leakey
Posted 13 June 2006 - 10:05 PM
_Swampy_
Posted 14 June 2006 - 12:20 PM
_gm3300_
Posted 14 June 2006 - 03:29 PM
It works really well, holds the speed within a tight range (considering it's no fireball and has the most unresponsive auto ever made), also makes a big difference to fuel consumption.
grant
Edited by gm3300, 14 June 2006 - 03:31 PM.
_Swampy_
Posted 14 June 2006 - 04:13 PM
_gm3300_
Posted 14 June 2006 - 04:40 PM
grant
_Swampy_
Posted 14 June 2006 - 07:34 PM
_Oldn64_
Posted 15 June 2006 - 06:13 PM
The Galant has 4.11 and I had an issue using two magnet as per insturctions as the diff ratio was too high. If you have 3.36 or lower you will be right, firstly might would nto keep 110km or 100kh as it ran out of sensing count at about 95km. solution was to increase sensitivity or loose a magnet.
PS: Matty, easy to do great investment and neat to install. Cheapest kit is about $180
_devilsadvocate_
Posted 15 June 2006 - 08:25 PM
_Oldn64_
Posted 16 June 2006 - 02:50 AM
Generally they come with mounting brackets and run off your tB or throttle cable itself. My setup was placed inside (never again the solenoid is hell noisy) and runs of my accelerator pedal. If I did it again I would place the solenoid somewhere outside but still not in teh engine bay (like having people not see things like that..All the speed sensor stuff sounds 'easy enough', but how about the mechanics of the throttle control, how are they setup...adaptability to different setups, how much space do they require...mounting brackets etc?
_devilsadvocate_
Posted 16 June 2006 - 07:52 AM
_Swampy_
Posted 16 June 2006 - 08:32 AM
I'll take photo once I've got it working.
_gm3300_
Posted 16 June 2006 - 09:19 AM
grant
cruise setup
Posted 16 June 2006 - 12:48 PM
DA, it's quite a small unit - the throttle actuator unit is not much bigger than a tennis ball, and it has a small rectangular control unit to mount under the dash. I mounted the switches onto the indicator stalk with P clips, so it was all removeable without leaving any extra holes.
On this model, the sensitivity is changeable by dipswitches on the control unit, and I used two magnets on the tailshaft without a problem. If you really have to drop to one magnet, don't just take one off, as this will change the balance of the tailshaft - move one magnet back slighlty so the pickup doesn't 'see' it. Oldn 64 is right about the location of the magnets. They need to be right up the front of the tailshaft, so that as the rear axle moves up and down, the tailshaft (which also obviously moves up and down with it) doesn't change its position relative to the pickup.
Another good thing about this model and some others, but not all, is that it uses tacho sensing to shut off the cruise control setting. This is so that if the car is shifted into neutral or the clutch is pushed in while the car is 'in cruise', the sudden increase in revs tells the unit that it's out of gear, and it drops the car out of cruise mode. This means that you don't need a clutch switch for a manual, or a selector switch for an auto.
Swampy, the cruise control cable shouldn't have to push the throttle closed. Your existing throttle spring should be seeing to that. All the cruise contrl cable should have to do is go slack when it wants to decelerate, and the throttle should be pulled closed by the throttle return spring.
_Swampy_
Posted 16 June 2006 - 04:28 PM
