New Alloy Radiator( where in Perth?!)
32 replies to this topic
#26 _judgelj_
_judgelj_
Posted 19 December 2012 - 03:42 PM
Give bad feedback and item not received dispute.
#27 DanWA
DanWA
  • 2,440 posts
  • Car:LS1 LX 4 Door
Posted 19 December 2012 - 03:55 PM
If you want a Browns Radiator, happy to do you a discount on mine as i need to order another from him since going to Electric Water Pump to avoid having to run a big crossover pipe.
His radiator/fans/shroud combo is usually $1180, happy to do mine brand new in the box for $900 so i can order the same thing with a different inlet/outlet setup.
#28 _76S.L.R_
_76S.L.R_
Posted 20 December 2012 - 07:37 PM
I got the Cheapy radiator modified,I had a 5mm plate welded on then we drilled and tapped the hole to accept the thermo fan sensor,I just need the braided tranny hoses made up( tomorrow) ,still got to redrill some holes in the sidebands and refit the AU Fans then I can put it all back together.
I bought the Genuine Toyota long life coolant today( total cost was $48.20) , I had to buy a 4 litre and 1 Litre bottle ( you have to mix it 50% with water) Coolant container says to use distilled water with the coolant, does it really matter if you use tap water???
Edited by 76S.L.R, 20 December 2012 - 07:38 PM.
#29 dattoman
  • 16,488 posts
Posted 20 December 2012 - 08:32 PM
Tap water contains fluorine , chlorine and many other nasties to make it drinkable
These can effect your rads life expectancy
Use distilled
#30 _76S.L.R_
_76S.L.R_
Posted 20 December 2012 - 09:14 PM
I'll go try find some distilled water then,Cheers.....
#31 dattoman
  • 16,488 posts
Posted 20 December 2012 - 09:27 PM
Any auto parts store will sell you a 15L goon bag in a box... cheap enough too
#32 _76S.L.R_
_76S.L.R_
Posted 20 December 2012 - 09:40 PM
You know what Ive only ever seen Distilled water at the Supermarkets in big 5 litre? bottles,never have I seen it an Auto parts Shop?.
Edited by 76S.L.R, 20 December 2012 - 09:41 PM.
#33 dattoman
  • 16,488 posts
Posted 20 December 2012 - 09:49 PM
Part # DIS15
I used to carry it at both Covs and Auto 1 when I worked at both places
