VN rear Brakes
#1 _toddy_
Posted 13 June 2006 - 09:40 PM
Basically the centers need to be welded up and bracketry removed, rotated and replaced
I dont really know how to explain it so I will put up the pics and hope they help
New backing plate with hand brake mech moved.
left is original Right shows that the brake caliper holder part and hand brake mech has been moved.
(the part shown on left is what needs modifying)
Flip side of same. (note hand brake lever slot)
The end result.
Torana brake lines fit but I need new ones as mine were cut.
The next photo shows why I had my brakes put to the front (they hit the shockies BAD)
I hope this can help you guys as I found it confusing but it is an easy conversion once you put your mind to it.
P.S. I was told to use the torana hand brake cable and find a cable company to put commodore ends on that..
#2 _QIKSLR_
Posted 20 June 2006 - 07:46 PM
I understand what you've done with the backing plate, but I can't make sense of what you modified on the bit the handbrake mech goes in.
Also with the handbrake cable, I reckon a commodore wagon/ute handbrake cable is the go. It'll mount up at the front the same, it'll mount to the rear brakes obviously. Only thing is it's a bit longer than standard, but a few spacers up front will sort it out. The stock commodore cable is too short. Only difference with mounting is instead of mounting to those hooks on the side it bolts to the floorpan.
Posted 21 June 2006 - 10:36 AM
Posted 21 June 2006 - 04:35 PM
The EF & later Fords use a handbrake sytem similar to the VT & later Commodore. It's called the Banksia handbrake, is Australian designed & uses on 1 shoes not 2. It is totally different from the unit pictured above.
The handbrake on all rear disc Commodores from VB to VS use the Opel set-up with 2 shoes.
Dr Terry.
#5 _QIKSLR_
Posted 22 June 2006 - 01:22 PM
Posted 22 June 2006 - 03:42 PM
#7 _QIKSLR_
Posted 23 June 2006 - 08:23 AM
Very slowly dude! Funds are very tight at the moment. I'm hoping to have it painted this year. In the mean time I'm trying to get all my suspenion sorted out so I can get it rolling again.how is that beast of yours coming along Bomber?
Marty
#8 _brett_32i_
Posted 23 June 2006 - 09:21 PM
#9 _LX8VD69_
Posted 24 June 2006 - 06:39 PM
if you havent shortened the diff then it just fits, there is about an inch clearance so if was you i would put new rear shockers on first as you will hace to remove the whole brake set up to get the bottom of the shocker off, well i would have to for mine. the problem i am having and i dont know if any one else is that the axles arent sitting home so the rear seals arent sealing and theres oil leaking out, i had to get some 1/4 inch spacers made to fix that. i used old bearing cups as they are already the perfect size they are just too wide, i just got them machined to 1/4 inch thick. i havent put them on yet but my mechanic says hes done this before on f#*ds so im gonna get him to do it for meI already have the commodore rear discs setup. Only issue is caliper clearance.
#10 _QIKSLR_
Posted 26 June 2006 - 09:06 PM
Have you got the right oil seal mate? Fords have a different oil seal for drums and disc brakes. Are you using the cone type barings? I had to change my oil seal and had to get my axel shorted slightly as the oil seal was overhanging, but I found that the axel was actually bottoming out on the pin in the diff center. So I had a few mm shaved off the end and now it fits.if you havent shortened the diff then it just fits, there is about an inch clearance so if was you i would put new rear shockers on first as you will hace to remove the whole brake set up to get the bottom of the shocker off, well i would have to for mine. the problem i am having and i dont know if any one else is that the axles arent sitting home so the rear seals arent sealing and theres oil leaking out, i had to get some 1/4 inch spacers made to fix that. i used old bearing cups as they are already the perfect size they are just too wide, i just got them machined to 1/4 inch thick. i havent put them on yet but my mechanic says hes done this before on f#*ds so im gonna get him to do it for meI already have the commodore rear discs setup. Only issue is caliper clearance.
Yeah, my diff is shortened. Here's how close mine is:
#11 _LX8VD69_
Posted 26 June 2006 - 09:52 PM
#12 _73lj202_
Posted 27 June 2006 - 08:29 AM
The man who designed this system is Nui Wang. Avery nice & clever bloke!Hi Guys.
Dr Terry.
#13 _355lxss_
Posted 27 June 2006 - 03:04 PM
QIKSLR; looks like your very close to touching there! How much have you shortened you diff by?Have you got the right oil seal mate? Fords have a different oil seal for drums and disc brakes. Are you using the cone type barings? I had to change my oil seal and had to get my axel shorted slightly as the oil seal was overhanging, but I found that the axel was actually bottoming out on the pin in the diff center. So I had a few mm shaved off the end and now it fits.
Im wanting to run vn disks too but i have gotten my diff shortened by 2 1/5 inches either side. Ive dont think it would clear the inner gaurd or shocker?
#14 _QIKSLR_
Posted 27 June 2006 - 08:28 PM
Ah, I reckon it's an oil seal issue.nah im still using a bango
355LXSS, I think my diff is only shortened an inch all up, so I reckon you'll definately will have problems. However if we can work out how to do the above mod, we'll all be sweet.
#15 _J&S Racing_
Posted 27 June 2006 - 09:06 PM
#16 _toddy_
Posted 07 July 2006 - 04:06 PM
I havent been on here for a while and I am guessin that you all need to know how the hand brake works
As in the pics the backing plate needs to have the hand brake mechanism removed and rotated, Basically turned around so the left and right sides can be swapped
I dont have an old backing plate but I will try to get one so I can post a pic of that
I will also pull a wheel off and post a pic of my brakes mounted with no rotor so you can see how it looks...
I can see this in my head but it is hard to explain
get original backing plate and place on axle
Observe where hand brake mechanism sits (this needs to be moved)
Remove hand brake mechanism
rotate backing plate to desired position
replace (weld in) hand brake mechanism
axle mount bolt holes need redrilling and relocation
splash gaurd needs to be either re drilled or redrill the backing plate
bolt it all together and done
Now that I have written this I am going to get an old backing plate and cut it up and take photos to show you...That will be easier....
OR
cut around the base where the dust cover joins rotate that and weld in ( not reccomended) but easy
#17 _youngy_11_
Posted 08 July 2006 - 09:19 AM
What disk set up is the easiest and cheapest to fit to a LX hatch with (i think) a banjo diff??
I have read the article with the UC disk brakes and they look quite easy to fit, but will the commodore ones be much better that those.
Any info appreciated.
thanks ryan
#18 _Aidan_
Posted 10 July 2006 - 11:43 PM
Posted 21 October 2006 - 08:45 PM
Andy
#20 _2wild4u_
Posted 23 October 2006 - 08:51 PM
#21
Posted 24 October 2006 - 02:06 AM
A photo would be appreciated.
Andy
#22 _TOBES_
Posted 27 October 2006 - 08:07 PM
I am fitting up a VN setup now and plan to mount the new bracket using the bottom caliper bracket bolt and the bottom backing plate bolt.
Will see what I can do about a photo...
