308 cam timing
, Jun 14 2006 07:25 AM
10 replies to this topic
Posted 14 June 2006 - 07:25 AM
is it 9 links between the marks??? I know the Max Ellery book had mistakes.
Posted 14 June 2006 - 09:26 AM
Yes.
Posted 14 June 2006 - 09:32 AM
thanks mate
Posted 14 June 2006 - 11:39 AM
its definatley 9.
how many does the ellery book say? 7?
Posted 14 June 2006 - 08:31 PM
isnt it 7 between the marks and 9 dot to dot.
#6 _Yella SLuR_
Posted 14 June 2006 - 08:50 PM
9, I found that error in the Ellery book, it only show's 8 in the repeated wrong picture.
#7 _JNR_ATE_
Posted 15 June 2006 - 02:07 AM
What does it matter if your dialling your cam in perfectly off piston head and lifter.
JNR_ATE
JNR_ATE
#8 _Yella SLuR_
Posted 15 June 2006 - 02:50 AM
You can only dial a cam in if you have variable timing gears fitted.
Posted 15 June 2006 - 03:57 AM
we used to drill a new hole back in the econo dayz.You can only dial a cam in if you have variable timing gears fitted.
Posted 15 June 2006 - 08:16 AM
ok found this...
#11 _Oldn64_
Posted 15 June 2006 - 05:43 PM
I have always used the rolling pins as teh guide which equates to 16. Which funnily enough is teh same as the pic above. When building always rotate the motor by hand once finished as this will tell you whether you have got the timing off(ie the neighbours meet... Mr piston and miss valve, to make the messy family)
It is also an idea to grab a degree wheel and see what rating the cam comes up as this will give you an even better idea of how close teh cam is to right, even if you do not have an adjustable timing set it still gives a great understanding of what is going on.
