strong diff for LJ
15 replies to this topic
#1 _T0rana_
_T0rana_
Posted 19 February 2013 - 07:06 PM
i want a strong diff for my 6cyl LJ to handle burn outs ect whats the best choice to go for?
and what cost and place would somone recommend in brisbane
#2 Ice
  • 15,205 posts
Posted 19 February 2013 - 07:15 PM
9 inch but some others will say borg wanker diffs or vn crap
#3 _T0rana_
_T0rana_
Posted 19 February 2013 - 07:23 PM
will a 9 take away to much power
#4 Ice
  • 15,205 posts
Posted 19 February 2013 - 07:26 PM
Maybe but do you want to be changing diffs often
#5 Shtstr
Shtstr
    Formerly lcxu105
  • 1,810 posts
  • Name:Mmmmmmm
  • Car:lx hatchback lc gtr
Posted 19 February 2013 - 08:56 PM
with a 9" you will lose an exra 15% hp at the wheels. You need to remember these diffs where made for trucks not cars. Any diff will not last long with burn outs unless it is built for it. You are looking at a full spool and 3.5-4.11 gears and a in line locker  for the brakes so your not loading them up and putting more strain on the diff.
A well built borg warner diff with a full spool and 28-31 spline axles will be good enough for a holden 6.
If you do go down the road of a full spool just remember that they are not permitted in a street car so you will have to settle for a LSD centre. Being a cone type LSD they don't like burn outs.
So changing the carrier to something like a detroit locker or a is a big improvement and is permitted on the street as they are not locked all the time.
I run a 10 bolt salisbury with a 4 pinon carrier set up same as a borg warner 4 pin set up.
Works well for all street driveing and some light track work and the odd lauch off the line at the drags.
#6 enderwigginau
enderwigginau
    Admin Wrangler
  • 2,000,527 posts
  • Name:Grant
  • Car:76 LX Sedan, 4 seater
Posted 19 February 2013 - 09:27 PM
As per Dave above.
Replacement centres will also be cheaper should you need them.
A 9" is overkill behind a Holden six.......
Grant..
#7 ls2lxhatch
  • 5,332 posts
Posted 20 February 2013 - 01:58 AM
According to Strange Engineering the 12 bolt centre is 3% more efficient than the 9" centre due to the height of the pinion in relationship to the centreline of the crown wheel. Strange Engineering make a 12 bolt centre section to suit the 9" for those that want the 3% back.
The Hilux diff was a popular choice for the LJ.
#8 _Agent 34_
_Agent 34_
Posted 20 February 2013 - 05:12 AM
Thought that this was also mentioned here
http://www.gmh-toran...rgwarner-diff/
and  here
http://www.gmh-toran...rg-warner-diff/
and someone to built it for you
http://www.gmh-toran...s-in-sth-aust/
there was also a thread on some guy who did the hilux conversion to rear disk breaks as well but cannot find it
#9 warrenm
warrenm
  • 2,118 posts
  • Car:1972 LJ Torana
Posted 20 February 2013 - 06:40 AM
Hilux diff, 2kg heavier than a banjo, plenty of ratios. 500+ passes(I'll have to count them again one day) std Toyota axles & the splines are still straight.
#10 _nicko61_
_nicko61_
Posted 20 February 2013 - 08:07 AM
hilux diffs are cheap and strong ,although ratio changes get very expensive so pick one with good ratio for your setup as centre changes are as expensive as 9" centres
#11 Dave6179
Dave6179
  • 577 posts
  • Name:David
  • Car:HJ, VN, VX SS
Posted 21 February 2013 - 01:26 PM
Just read about a blown Charger, in Aus, 265, 9 sec car, Borg Warner diff.
#12 _tyre fryer_
_tyre fryer_
Posted 22 February 2013 - 08:46 AM
You won't break a BW with a 202.
#13 Dave6179
Dave6179
  • 577 posts
  • Name:David
  • Car:HJ, VN, VX SS
Posted 23 February 2013 - 06:48 AM
And, what the hell would a 9" wiegh compared to a salisbury or BW?
#14 ls2lxhatch
  • 5,332 posts
Posted 23 February 2013 - 12:13 PM
There are so many options with a 9" that you can not compare weight or strength without being specific about the components used to build the 9". You can not reasonably compare the weights of diffs without being specific about the centre used in each diff (open,  LSD, locker, mini spool, full spool, etc.) and removing the brakes from the equation.
The 9" can be built lighter and strong than the Salisbury and BW M78.  The Salisbury and BW M78 are stuck with a cast iron centre housing. The 9" has the option of lightweight centres and housings.
Approximate weights
Banjo open centre no brakes 50 kg
BW M78 open centre no brakes 58 kg
Truck 9" LSD centre no brakes 70 kg
#15 _nicko61_
_nicko61_
Posted 25 February 2013 - 07:28 AM
http://www.ebay.com....=item43b4f43ce4
looks like a great buy for any tough torana
#16 _nostolgia186turbo_
_nostolgia186turbo_
Posted 25 February 2013 - 08:31 AM
ive broken / smashed to pieces those borg warner diffs years ago in my old hr & eh holdens . ive clean snapped 28 spline nine inch axles in one of my torana 6 cyl strokers - proberly due to bad workmanship more than anything . THIS time with my turbo 6 cyl ive gone back to the 9 inch but with moser 31 spline axles - if you have to worry about the little bit of power lose then your simply not making enough power to start with lol .
