Urgent!!! LX Steering
Posted 19 June 2006 - 05:36 PM
HELP!! please!
#2 _Yella SLuR_
Posted 19 June 2006 - 06:17 PM
They are prone to cracking here, and need to be MIGged back up (you need experience with thin metal/panel welding). I got mine done professionally as I don't stuff with things that control my ability to stop or steer. Cost about $120 to get my column rebuilt, and $70 for a donor column.
I also got pinged for a faulty steering bearing for rego, so didn't have time to stuff around with it myself.
Donor column outer also had a crack, but not as bad as mine was. It got migged. The old column is waiting for my MIG to return home.
Edited by Yella SLuR, 19 June 2006 - 06:19 PM.
Posted 19 June 2006 - 06:25 PM
#4 _Yella SLuR_
Posted 19 June 2006 - 06:34 PM
Other alternative is to take the column down and get them to fit it, or is it still in the car? Yella remembers that involves removing prick cotter pins.
Edited by Yella SLuR, 19 June 2006 - 06:34 PM.
Posted 19 June 2006 - 06:36 PM
whats you email address?
#6 _Yella SLuR_
Posted 19 June 2006 - 06:42 PM
Posted 19 June 2006 - 06:48 PM
Posted 19 June 2006 - 06:50 PM
Posted 19 June 2006 - 07:35 PM
Can u see the grease in your new bearing?
if not its sealed.They just stop grease escaping and crap getting in bearing
Posted 19 June 2006 - 07:40 PM
Posted 19 June 2006 - 07:43 PM
Posted 19 June 2006 - 07:44 PM
thats no good.Was the bearing really loose in where it was sitting?
sounds like your bearing has seuzed and worn into your column
Posted 19 June 2006 - 07:47 PM
Posted 19 June 2006 - 07:51 PM
Posted 20 June 2006 - 01:33 PM
Laspy, you could try to put the new bearing in, and tap around the top of the die cast section with a ball pein hammer to get the die cast metal to fold over the top of the bearing, but be gentle about it.
#16 _Yella SLuR_
Posted 20 June 2006 - 03:46 PM
Edited by Yella SLuR, 20 June 2006 - 03:47 PM.
Posted 20 June 2006 - 04:33 PM
This is commonplace right up to VL as far as I am aware.
My experience, not very common for this bearing to wear out as you described. Check the rest of the column and ensure all other bits a good otherwise it will chew your new bearing sooner.
Cheers, Max
PS: Are you the owner of the white replica A9X who like to eat Hungry Jacks?
Posted 20 June 2006 - 05:32 PM
I agree with hatchssv8, I had the same thing. I believe that the metal that has come away is original factory, (original retainer). It has to be a servicable bearing, eventually any bearing will have to be replaced. So the metal that came away with removal of the original bearing, is normal. I have replaced mine about 2000kms ago and havent noticed any problems. Grease up all your indicator and ign moving parts with inhibitor (elec grease) while your in there.
Posted 20 June 2006 - 06:20 PM
#20 _TUFF_
Posted 13 July 2006 - 09:56 PM
Josh
