celica 5 speed conversion for 308
bullitA9X
, Jun 19 2006 07:17 PM
2 replies to this topic
Posted 19 June 2006 - 07:17 PM
Hi guys 1st gear in my v8 m20 in my lj 5 litre has shit itself
my question is i can buy a complete celica 5 speed conversion to suit a lc 6 cyl what would i have to do to make it fit the v8 besides a new bellhousing would i have to change the front input shaft and how much stronger are the celica boxs as my lj 308 is not stock also does the gear stick come out the same hole any help would be great
Posted 19 June 2006 - 07:22 PM
Gday mate,
I think a supra gearbox would be a bit better in your car.
u can usually pick these up fairly cheap in the trading post.
if u have trouble finding one give us a bell
Damo
Damo
Posted 19 June 2006 - 08:12 PM
stick position may be the samedepending on what it came out of.
there are many different bellhousings for this conversion, ensure you purchase one with your clutch linkage in mind or you will have to change that aswell.
input shaft stays but you will need a toyota clutch plate.
celica box is only as strong as how hard you treat it, meaning it will support a mild V8 if you drive it with a fluid motion changing gears. if you gonna smash it on the red line thru each gear every day then this might not be the box for you.
