is a capasitor to ground needed when setting up the electronic ignition say from VK commy to LH-LX.
HEI capasitor
, Jun 19 2006 09:07 PM
5 replies to this topic
Posted 19 June 2006 - 09:07 PM
#2 _munro_
Posted 20 June 2006 - 12:31 AM
i never used one for mine and it works fine
tom
tom
Posted 20 June 2006 - 10:28 AM
Hi Guys.
The capacitor you a refrerring to is only a radio noise suppressor. It runs from the coil +ve to ground.
The HEI's operation won't be affected by it being there or not. If you have a 12v ignition noise problem in your car's audio system you will probably need one.
Dr Terry.
Dr Terry.
Posted 20 June 2006 - 07:23 PM
maybe i should have called it a condensor, is this different to a capacitor.
Posted 18 July 2006 - 01:39 PM
Nup, condensor is just an old name for a capacitor.maybe i should have called it a condensor, is this different to a capacitor.
#6 _1978SSHATCH_
Posted 31 July 2006 - 05:26 PM
Hi guys, the capacitor is there not only for radio noise suppression but for HEI system spike suppression, to prevent damage to the HEI, hope this helps.
