Crappy plastic distributor gear snapped!
#1 _mike_nofx_
Posted 19 June 2006 - 09:26 PM
Couldnt have happened at a worse time, Friday arvo leaving work, just come out of the gates and the car dies.
Called NRMA, and he tells me whats wrong and i get a free tow home (aint NRMA awesome). Turns out to be a $19 piece of plastic crap.
Does anyone know where to get a steel gear? i rang around but only ONE place had one, Repco, and it was plastic (i got it anyway).
Posted 19 June 2006 - 10:29 PM
I sell 2 or 3 a week
Now for a metal gear try Crow Cams..... they do a bronze one
Repco or other auto parts should be able to source it
Part # BG2
Posted 19 June 2006 - 10:35 PM
#4 _TORANASS_
Posted 19 June 2006 - 10:36 PM
John
#5 _devilsadvocate_
Posted 19 June 2006 - 10:37 PM
#6 _TORANASS_
Posted 19 June 2006 - 10:39 PM
John
#7 _devilsadvocate_
Posted 19 June 2006 - 10:47 PM
afaik all blue motors got plastic gears, electronic dizzys with metal gears would be replacements. Not sure when the plastic ones were introduced, possibly late 70s.Try a Blue motor electronic Ign, I had a few with metal gears, they also fit a points dissy, maybe ring GMH and ask for a spare part for a blue elec dissy and see if they have it..
John
There should be thousands of metal ones at wreckers, AFAIK, all red,BLUE,BLACK motors use the same dizzy drive.
Believe there is merit in the idea with the cams, but fail to understand why an aftermarket cam for a holden wouldnt be manufactured to match the dizzy drive?
The other idea is that the distributor drive is easier to replace than the camshaft so best to have it suffer the wear. Having never had a cam drive fail on any old holden using metal dizzy drives, I cant say I support the idea. Plastic was most likely used just to reduce costs, the logic being 150000km should be fine, you should have bought a new car by then!
Edited by devilsadvocate, 19 June 2006 - 10:51 PM.
#8 _TORANASS_
Posted 19 June 2006 - 10:50 PM
Ok cool, all i know is iv had a few elec ones that had metal gears and they worked as a replacement for the plastic gear..afaik all blue motors got plastic gears, electronic dizzys with metal gears would be replacements. Not sure when the plastic ones were introduced, possibly late 70s.Try a Blue motor electronic Ign, I had a few with metal gears, they also fit a points dissy, maybe ring GMH and ask for a spare part for a blue elec dissy and see if they have it..
John
On another note if a plastic gear lasted 30 years befor it crumbled them maybe just a new plastic gear will last another 30?
John
Posted 19 June 2006 - 11:10 PM
my reasoning is that maybe it was the plastic that failed due to the cam needing a metal gear.
Posted 20 June 2006 - 12:02 AM
Posted 20 June 2006 - 12:18 AM
cant help but comment tho when you think u might save someone some grief and some cash.
bronze and steel cannot be interchanged i think.
bronze for billit steel and steel for cast?
Edited by ALX76, 20 June 2006 - 12:21 AM.
