manual Column Shift fit with the a v8
36 replies to this topic
#1 snickersbar
snickersbar
  • 91 posts
  • Name:Leigh
  • Car:LX torana S
Posted 04 March 2013 - 08:37 PM
hi all im new here just wonding does 3 speed manual column shift fi under the bonnet with a v8 in there??
#2 snickersbar
snickersbar
  • 91 posts
  • Name:Leigh
  • Car:LX torana S
Posted 10 March 2013 - 09:42 PM
any help??
#3 rodomo
  • 18,050 posts
Posted 10 March 2013 - 09:48 PM
We're talking big Torana?
Dunno? Don't think anyone would off hand? I don't think that was ever factory (but I could be wrong?)
You could be a pioneer here!
#4 snickersbar
snickersbar
  • 91 posts
  • Name:Leigh
  • Car:LX torana S
Posted 10 March 2013 - 10:03 PM
i was talking about lx torana, i know the that a 3 speed came out for sixers with a manual steering column shift
just seeing if you can uses it with 253
#5 rodomo
  • 18,050 posts
Posted 10 March 2013 - 10:14 PM
Maybe? HT, HQ etc came with column 3 speed and V8. But I'd reckon it would be an adaption in your case.
#6 snickersbar
snickersbar
  • 91 posts
  • Name:Leigh
  • Car:LX torana S
Posted 11 March 2013 - 09:11 PM
das anybody has manual steering column for an LX torana going cheep in melbourne??
#7 _abtorana_
_abtorana_
Posted 13 March 2013 - 11:12 AM
if your worried about it fitting just pull it apart and remove the column shift stuff
assuming you are not using the column shift
mine was a three speed and has had the selector gear removed.
i have just pulled it apart again to remove the control tube so i could do the "Lower Bearing mod"
not very hard at all just may need an extra set of hands when removing/replacing top circlip.
just need to be careful with inner steering shaft that u do not accidently shorten it .
the gregory's manual has some good exploded pics
regards
#8 TerrA LX
Posted 13 March 2013 - 11:31 AM
I say do it, how cool, a 3 speed column change manual V8 Torana.
Is your car 3 speed manual now?
6cly 3 speed bolts up pretty much the same as a V8 3 speed so only problem I can think of would be selector rod length as the bell housings are different length.
#9 yel327
  • 13,711 posts
Posted 13 March 2013 - 03:56 PM
3spd column shift was standard fitment to 6cyl LH-LX. Everything for a V8 column shift is the same as 6cyl stuff, gearbox stays in the same place, only reason V8 boxes have a longer input shaft is the V8 Holden engine is shorter and thus the input shaft has to be longer to reach the engine (historically, if GMH had continued with Chev V8 engines the gearboxes would be the same for Holden 6 and Chev V8, just like Saginaws are. But Holden V8 is shorter than the Chev). The only complication might be with clearance to the clutch rat-trap off a LH-LX V8, just use a mofified UC pedal and full cable bellhousing and it should all be sweet. There won't be a lot of room for exhaust though, I doubt you would be using off the shelf extractors. I'd try dummying it all up first too to make sure shift rods clear the V8 engine and bellhousing as well as the rods and column are in a different orientation than they are on HQ-WB.
Edited by yel327, 13 March 2013 - 03:58 PM.
#10 A9X
A9X
    A fortunate run
  • 5,024 posts
  • Name:Welby
Posted 13 March 2013 - 04:46 PM
i have a really great condition 3 speed coloumn.
but i'm in perth
#11 snickersbar
snickersbar
  • 91 posts
  • Name:Leigh
  • Car:LX torana S
Posted 13 March 2013 - 07:08 PM
my not 3 speed yet, im picking up a gearbox up 2moro nite, im gona use the the V8 parts off my 4 speed box, just need a steering column with the linkages
mite sell my lower dash which is uncut to help pay for a column
#12 rodomo
  • 18,050 posts
Posted 13 March 2013 - 09:12 PM
Exhaust clearance would be the biggest issue I would think?
#13 snickersbar
snickersbar
  • 91 posts
  • Name:Leigh
  • Car:LX torana S
Posted 13 March 2013 - 09:25 PM
yeah frist im gona get the box and linkages set up frist and go from there
#14 yel327
  • 13,711 posts
Posted 14 March 2013 - 01:43 PM
V8 4spd stuff won't help you, you need a HG-WB V8 3spd input shaft. The V8 4spd input shaft cover will fit as long as it is the same seal type.
One other thing to think about, is you can use the 3spd column setup to operate a 4spd, so it gives you 4 on the tree! They have the exact same side slectors. But you have to figure out some way to operate reverse, like a cable operated setup, and you can only use it when you put the 4spd in neutral on the column. You'd have to also disconnect the reverse swith on the column and run the 4spd reverse switch wiring down to the 4spd's reverse switch. I guess you could try a transfer case solenoid off a late model 4x4 to operate the reverse lever on the 4spd.
#15 snickersbar
snickersbar
  • 91 posts
  • Name:Leigh
  • Car:LX torana S
Posted 14 March 2013 - 08:16 PM
well the gearbox i got is out of an HR, got it for free, ill ring up some holden wrecks 2moro to price up an input shaft for it.
did think of use my 4 speed for it and useing cabe or some kind of switch too
#16 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 14 March 2013 - 08:25 PM
I saw an EH with a 4 on the tree back in 1982, it was owned by a bloke I worked with at the time. Nobody could work out where reverse was.
#17 TerrA LX
^ or just put a short lever on the floor to knock it into reverse.
#18 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 14 March 2013 - 08:36 PM
I'm not sure what one of those setups would be worth, but I do have one. I would only consider a trade for the bits needed to convert the car to auto. So a trimatic, converter, flexplate and some sort of shifter. An aftermarket trans cooler would be handy, as I have a manual radiator. But I can always buy one of them easy enough.
#19 snickersbar
snickersbar
  • 91 posts
  • Name:Leigh
  • Car:LX torana S
Posted 15 March 2013 - 09:07 PM
i dont having any auto part for trade
#20 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 16 March 2013 - 08:05 PM
That's fine, just offering a possible solution.
#21 Dr Terry
Dr Terry
  • 3,327 posts
Posted 17 March 2013 - 09:19 AM
 The box you have is a 3-sp all-synchro (M15) isn't it ? An original HR is not going to fit.
Dr Terry
#22 snickersbar
snickersbar
  • 91 posts
  • Name:Leigh
  • Car:LX torana S
Posted 17 March 2013 - 12:27 PM
So you can't put an V8 input shaft in to it??
Dr Terry
#23 Dr Terry
Dr Terry
  • 3,327 posts
Posted 17 March 2013 - 01:00 PM
No, totally different box. You won't find a V8 bellhousing for it either.
Dr Terry
#24 _Quagmire_
_Quagmire_
Posted 17 March 2013 - 01:26 PM
Dr Terry
i thought hr's where still the opal non synchro first boxes...
#25 snickersbar
snickersbar
  • 91 posts
  • Name:Leigh
  • Car:LX torana S
Posted 17 March 2013 - 02:02 PM
Dr Terry
So it won't bolt on to an M20 V8 bellhousing
