Diff Whine
34 replies to this topic
#26 _jklumpp_
_jklumpp_
Posted 07 April 2013 - 05:22 PM
OK, thank you all for your input - here's where I'm at...
I went out to the local diff shop that has experience with banjos.
I explained to him what was happening, and without hesitation he said pinion & crownwheel - when I asked for clarification on what he meant, he said 'they're stuffed'
I questioned again if there could be any other explanation, and he said 'no - whine on load is gears - they need to be replaced, and good 3.08:1 Banjo gears are getting hard to get'
\.... So, I pulled the centre out today to see if I could see anything. I thought there was a more noticable 'shine' on the gears than what I could remember, and also a sharp edge on the crownwheel teeth that I'm not sure was there before....AND THEN I NOTICED.... one of the bearing cap bolts was loose!
I'm guessing this has played a part, but unsure now whether it has stuffed the gears or not?
While I've got it out, I'll try & take it back out to the diff shop tomorrow and see what he thinks. But if it's buggered, I'll tighten up the bolt & put it back in - and then expedite the BW conversion....
Question is, if it is still whining, is running it in the car until I get the BW sorted going to cause any other problems (other than the unbearable noise)?
#27 S pack
  • 15,737 posts
Posted 07 April 2013 - 06:07 PM
If you put it back in treat it gently as the wear in the gears will get worse quickly if the case hardening is worn away.
Worst case, you might lose a tooth/teeth or parts thereof off the gears.
#28 Bernie
Bernie
  • 301 posts
  • Car:2 lx Hatches and 3 lx 4 doors
Posted 07 April 2013 - 07:16 PM
Tighten it up look at the contact pattern and stick it back in .I think you will find it will quieten down .It is tooth contact when rectified it will usually stop whining .
Bernie
#29 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 11 April 2013 - 09:26 PM
Tighten it up, take it easy and save money for a conversion. I chipped a tooth off a banjo diff probably 25 years ago. It made a hell of a bang and then a load groaning noise. Still managed to drive it 5 KM home, though.
#30 _LJdave_
_LJdave_
Posted 11 April 2013 - 10:32 PM
I once caught a bum under the back of my 4WD trying to get the whine out of the diff??   :blink2:
#31 _jklumpp_
_jklumpp_
Posted 15 April 2013 - 08:04 PM
Tightened it up, and put it back in... there is wear on the edges of the teeth... whine is still there, but definitely a lot quieter than before.
#32 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 16 April 2013 - 08:19 PM
Well, it couldn't be any worse.
Or could it?
#33 warrenm
warrenm
  • 2,119 posts
  • Car:1972 LJ Torana
Posted 17 April 2013 - 07:54 AM
Turn the volume UP on the radio. :D
#34 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 17 April 2013 - 08:10 PM
That tends to fix a lot of engine noises as well.
#35 _jklumpp_
_jklumpp_
Posted 17 April 2013 - 10:10 PM
No radio..... just the sweet soundtrack of triple 45's
