HQ rad fit LJ
15 replies to this topic
#1 Gump
Gump
    Paisty White
  • 1,146 posts
  • Name:Russell
  • Car:LX SL hatch
Posted 21 June 2006 - 02:49 PM
g'day
when i took the V8 radiator out of my old HQ ute i gave it to my girlfriend for her car cause the engine shes got is fairly hotted up and used to run a v8 rad.
will a HQ rad Fit and LJ or is there a lot of piss farting around to get it in.?
PS. her dads a fitter, class one welder so i guess eh could do any mods.
#2 RIM-010
RIM-010
    DON'T PANIC
  • 8,076 posts
  • Name:Tim
  • Car:LJ 2 Door - HQ Premier
Posted 21 June 2006 - 03:03 PM
I'm pretty sure the top needs to be changed... ie: the hoses are on the wrong side.
RIM
#3 makka
makka
    A m��se once bit my sister
  • 3,559 posts
  • Name:Cohen
Posted 21 June 2006 - 03:22 PM
it will fit, but as rim said, the hoses top and bottom will be on the wrong sides for a 6, unless u have a chev v8 radiator
#4 _dave720gtr_
_dave720gtr_
Posted 21 June 2006 - 05:52 PM
you will also have to trim the side mounting brackets for it to fit bettween the rails
#5 RIM-010
RIM-010
    DON'T PANIC
  • 8,076 posts
  • Name:Tim
Posted 21 June 2006 - 05:55 PM
heey, i was right. Its always good to relay truthful information around.
I was planning the same conversion for my LJ, as i have a new V8 radiator at home.
RIM
#6 _troy_
_troy_
Posted 22 June 2006 - 01:22 PM
I whacked in a 6cyl HQ RADAITOR in my LC i just trimmed the edges up to fit does the job fine
#7 makka
makka
  • 3,559 posts
  • Name:Cohen
Posted 22 June 2006 - 02:32 PM
yes, we know they fit Troy, but the V8 ones wont be anygood because of the pipe locations.
just some useless info, the chassis rails on a LC/J are the same distance apart as on a LH/X! so basically any rad that will fit in 1 will fit in the other
#8 Gump
Gump
    Paisty White
  • 1,146 posts
  • Name:Russell
  • Car:LX SL hatch
Posted 22 June 2006 - 03:02 PM
cheers for all that guys.
didnt really think about the bloody hoses. bugger ill just go buy her a new one and keep her happy.
cheers torrie tree
PS thanks for the little tit bit of info makka
#9 _chevy_253_torana_
_chevy_253_torana_
Posted 01 July 2006 - 11:51 PM
how about vk commodore style ones can they be installed?? :P
#10 _munro_
_munro_
Posted 02 July 2006 - 12:25 AM
the radiator in mine is a chev /Hq radiator the chevs have the hoses on the same sides as the holden 6
i had to remove the fan for clearance
so i added twin 10" thermo fans to the front of the radiator
over heating is never an issue :rockon:
cheers tom
#11 To7ana1
To7ana1
  • 4 posts
  • Name:Nick
  • Car:1971 LC 4 door - Etruscan Gold Metallic
Posted 31 July 2021 - 05:24 PM
Old thread... Hopefully someone is listening... I have a HQ rad sitting in my LC right now and it is bolted in the oval holes and sitting up too high - the bonnet hits the cap. Is it trimming the bottom corners of the mounting panels that will allow it to sit down lower? Cheers
#12 piquet
piquet
  • 856 posts
Posted 31 July 2021 - 09:49 PM
I’ve fitted a VB,VC, VH,VK 6 cylinder radiator to my LC. The core is exactly the samedimensions as the cut out in the Torana radiator support panel. Drilled two holes on stone tray to mount and a bracket off the bonnet catch mounting bolts and no clearance problems under the bonnet.
#13 To7ana1
To7ana1
  • 4 posts
  • Name:Nick
Posted 01 August 2021 - 11:46 AM
Cheers piquet, but I already have the HQ radiator and would like to use it. Just wondering where to actually trim it.
#14 piquet
piquet
  • 856 posts
Posted 01 August 2021 - 01:39 PM
It will be the mounting flanges on either side of the radiator. You may have to redrill the mounting bolt holes as well.
#15 gtrboyy
gtrboyy
  • 3,141 posts
Posted 01 August 2021 - 06:52 PM
Yep cut the side panel untill it sits low enough..
#16 To7ana1
To7ana1
  • 4 posts
  • Name:Nick
Posted 02 August 2021 - 08:21 PM
Cheers for the confirmation... Shall have a bash on the weekend!
