LX shell weight
#51
Posted 25 August 2013 - 07:52 PM
#52 _Bomber Watson_
Posted 25 August 2013 - 08:02 PM
I would say a kilo of that goes on the ground.
So ues thats a frOckload of bog on the bonnet, sure ones not an earlyer model as they took a lot of weight oit of them in 76 or 77....
#53
Posted 25 August 2013 - 08:07 PM
Now we have to Weigh Bonnets and Doors etc to find their Variations Hey
#54 _LXSS350_
Posted 25 August 2013 - 08:43 PM
All Bare with etch primer only (no locks, hinges, bolts, windows etc)
Bonnet 20.80 kg
Front Drivers Door (hatch) 21.30 kg
Front Drivers Door Glass (hatch) 4.78 kg
Plenum panel 1.81 kg
Windscreen 9.52 kg
Windscreen rubber 1.36kg
Fender 5.00 kg
Hatch 19.20 kg
Nose Cone 4.08 kg
1/4 Panel (hatch) 9.0 kg
#55
Posted 25 August 2013 - 08:54 PM
Which hatch door is that ^ earlier ones were lighter with no side intrusion bar.
#56
Posted 25 August 2013 - 09:07 PM
Both are ADR27a as they have the emissions sticker on them. Just weighed them again on digital scales and got 18.8kg on the paint only and on the repaired one got 23.1. The reason I weighed them was I noticed one was heavier just by lifting them. The heavy one does have some rust proofing so that may add a little but there is certainly a few kg of bog there, looks to be just a thin coating over the whole surface.frOck me. I usually use ONE 4kg tin on an entire acco cab, and my panel beating is shit.
On the later model doors I have an intrusion bar from a front 4 door and it weighed a little over 4kg so I reckon an extra 5kg for a hatch door.
Also got a bare hatch and it weighed in at 17.8kg a little less than what LXSS350 got.
Hatch door with bar was 23kg .
Edited by tuxedoss, 25 August 2013 - 09:15 PM.
#57 _LXSS350_
Posted 25 August 2013 - 09:24 PM
The doors are late 77 with intrusion bar. Just fitted with new skins. The doors are fully primed with nothing in them.
I use the Intercomp 650 scales but old habits die hard and always measure cars in pounds. My weight distribution spreadsheet shows kgs once I enter what parts are going on the car.
http://www.racerindu...roducts_id=1231
Edited by LXSS350, 25 August 2013 - 09:32 PM.
#58
Posted 25 August 2013 - 09:37 PM
Edited by tuxedoss, 25 August 2013 - 09:39 PM.
#59 _LXSS350_
Posted 25 August 2013 - 10:05 PM
At $3k I hope they would be more accurate than a set of bathroom scales - LOL
Everything is either NOS and/or blasted inside and out, repaired, assembled and then primed and weighed bare (no fittings).
I measure everything right down to fender bolts as it all effects how the car will need to be set-up. (shock valving, spring rates etc). Throw on the carbon fibre door at 4.1kg or cf bonnet at 4kg, cf fender at 1kg etc and your front weight (with some other tricks) can get to 48% or better and bring your total weight well down on how holden built them. Less weight more speed, better distribution (weight) means better handling, braking.
Edited by LXSS350, 25 August 2013 - 10:08 PM.
#60 _sloffador_
Posted 25 August 2013 - 11:26 PM
I have a bare drivers side door that is bare and been dipped and yhe passenger door which hasn't been touched yet
ill weigh them both nd let you know
#62 _LS1 Hatch_
Posted 26 August 2013 - 01:31 AM
Stripped Hatch shell on the race scales was 507lbs (230.0362976 Kg)
Do the AA's mean the car was a hybrid ?
And interesting to see the numbers !
#63 _sloffador_
Posted 26 August 2013 - 04:49 PM
Bare door 13kg
Complete door 26kg
