Hi all
I did an auto to manual conversion on my LC a little while back .. http://www.gmh-toran...nversion-on-lc/ and all has been great.. except.... there has been a rattle developing and getting worse.
I thought of the usual suspects like clutch plate springs, thrust bearing and the like... this is actually the second clutch I have put in it as I got this noise from when I finished the conversion and thought they gave me a dud clutch kit... at least this one has lasted 2000 k's
Well... it got the better of me today so I ripped the box out to have a look... clutch plate springs are fine, thrust bearing seems ok... however... I did find the inner ring of the pressure plate was loose and making the noise... not sure what its called but the inner wire ring that sits under the rivet like things in the top pic below...
Also, the wear mark of the thrust bearing on the spring fingers looks to be very erratic.. not a smooth sharp wear line...
I looked at the first clutch kit I had in and that was the same... Is it just dud kits or is there something else going on? Anyone else had this or can offer some advice?
