Clutch Rattle
36 replies to this topic
#26 ribz0
ribz0
  • 512 posts
  • Name:Eric
  • Car:LC Torana & 1975 South African Mini
Posted 17 June 2013 - 04:48 PM
Thanks Dave...
I figure the dowels in the bell housing will do the trick there... you are right about the bolts though... I have a set for a earlier bellhousing and they have a shank on them... they just too short to use with this bellhousing so I got a set of normal bolts...
#27 ribz0
ribz0
  • 512 posts
  • Name:Eric
Posted 05 September 2013 - 09:49 PM
Hey all...
Been busy doing other stuff but thought I should let you know how it all went..
Well... Dave was spot on!!! again... I got a set of bolts, new clutch and got the box rebuilt...
All good now... I never even give it a second thought so thanks to all for the advice... Motor is coming along but a bit slow... I got myself another project so gotta share the funds.... lol..
Cheers all.
Edited by ribz0, 05 September 2013 - 09:51 PM.
#28 _LHSL308_
_LHSL308_
Posted 05 September 2013 - 10:04 PM
Hey Eric when you say clutch rattle what do you mean? Do you mean like a squealing sound? I have only had my car back a few months with a completely rebuilt engine, gearbox and new clutch. It seems to be developing a squealing noise mainly when its cold. Not sure where its coming from at this stage but definitely either the clutch or the gearbox.
#29 ribz0
ribz0
  • 512 posts
  • Name:Eric
Posted 05 September 2013 - 10:19 PM
Well.. it is more of a rattle... it sounded like a loose bolt type of rattle.. def not a squeal... does it go away when you put a bit of pressure on the clutch? Im thinking maybe thrust bearing? Also check that the thrust bearing is free to spin on the pressure plate, you maght have the clutch nipped up to tight on the adjustment...
My rattle ended up being that ring inside the pressure plate...
#30 _LHSL308_
_LHSL308_
Posted 05 September 2013 - 10:23 PM
Doesnt do it all the time but it was as bad as it has been this morning, seemed to do it whenever I selected reverse, 1st or 2nd. It only happens when the clutch is engaged which makes me think it has something to do with the throwout bearing too. Car is at the mechanics overnight getting a few other things done and the mechanic is going to have a look at it tomorrow.
#31 _Bomber Watson_
Posted 05 September 2013 - 10:29 PM
Agree sounds a lot like throwout bearing noise.
#32 S pack
  • 15,752 posts
Posted 05 September 2013 - 10:38 PM
+2.
Hey all...
Cheers all.
Good to hear that problem is sorted Eric.
Dave.
#33 _LHSL308_
_LHSL308_
Posted 05 September 2013 - 10:43 PM
I'll ask the mechanic to pay particular attention to the throwout bearing tomorrow. Any idea what to look for? Obviously it should spin nice and freely but shouldnt have any sideways movement. Anything else?
Edited by Gonedeaf, 05 September 2013 - 10:43 PM.
#34 _Bomber Watson_
Posted 05 September 2013 - 10:51 PM
It doesnt squeak when you turn it??
He's a mechanic.....
#35 _LHSL308_
_LHSL308_
Posted 05 September 2013 - 10:55 PM
I havent tried this mechanic before so his quality is unknown. Unfortunately my usual mechanic is booked for the next month and there were a few jobs that needed to be done asap.
#36 _Bomber Watson_
Posted 06 September 2013 - 07:18 PM
Aha. I see.
Some are a bit rugged....
#37 ribz0
ribz0
  • 512 posts
  • Name:Eric
Posted 31 January 2015 - 04:09 PM
Hi all...
Well, after finishing my other project... Im back to getting the engine done... However... that bloody clutch rattle is back!!
The plan this time is when I put the new engine in, I am going to go with the larger WB onwards flywheel and clutch set up. I dont know why this clutch rattle keeps coming up or the cause. I can only hope that changing the flywheel and clutch will fix it.... process of ellimination...
Will keep you posted...
