Broken Helicoil in block to head thread
43 replies to this topic
#1 _zooma355_
_zooma355_
Posted 17 June 2013 - 10:36 PM
Well i think this engine build has finally defeated me! While waiting for my manifold to be machined i thought id throw my heads on and torque em up... easy! Apparently not!
After cleaning out the threads, bitta spray glue on the gaskets, lube on the brand new ARP headbolts and at the last stage of the headbolt torque up the bolt nearest the back water jacket/driverside let out a loud crack.
After thinking id first broken the bolt, then that id broken my torque wrench i found that the thread in the block had let go! On closer inspection i found marks that look like they have thrown a helicoil in there and that it has snapped.
Ive had a gutfull of this engine! It hasnt given me a break on any single part of the build!
Anyway these are my options as far as i can see
1. drilling it back out and Re coiling or thread fastening the thread, what are my chances of success given it may have already been done and the closeness to the jackets?
2. stripping it all back down and sending it in to get done professionally
3. cutting my losses and getting a new block and starting again
What do u guys think? Have u guys heard of this happening and any possible remedies?
#2 N/A-PWR
  • 9,639 posts
Posted 17 June 2013 - 10:52 PM
Hi zooma355,
Maybe try welding and re-tapping the thread (although welding distorts the casting properties) first.
Re-coils are not a ridget type of thread for Torquing up. Dave I
#3 S pack
  • 15,736 posts
Posted 17 June 2013 - 11:04 PM
I would be seeking the advice of a professional on this one. The block may have suffered some hairline cracks around the bolt hole that can't be easily seen with the naked eye.
#4 _zooma355_
_zooma355_
Posted 18 June 2013 - 12:16 AM
Hi zooma355,
Yeah mate i probably wont go down that track as heating up that area is bound to cause dramas. Cheers
Yeah bud thats the way im leaning, i wouldnt have thought helicoils would be a solid enough thread for torque on cyl heads. Are there any other options u know of?
#5 rodomo
  • 18,046 posts
Posted 18 June 2013 - 12:23 AM
Studs? With a stepped stud in THAT hole.
#6 _zooma355_
_zooma355_
Posted 18 June 2013 - 12:38 AM
Na bud ARP headbolts, the thread goes all the way into the jacket so no chance of bottoming out. Plenty of sealant and thread lube under the head of the bolt so no idea.
Is it worth drillin out to see what depth the tapped threads turn out to be?
#7 S pack
  • 15,736 posts
Posted 18 June 2013 - 12:53 AM
No other options that I can think of if the thread has been damaged once before and helicoiled to repair it other than scrapping the block and starting from scratch.
#8 TerrA LX
If the helicoil have just failed you maybe able to bond a new one in place.
I have done this on lower tension studs, around the 30~40 pound mark but never tried on a 75 pound head bolt.
I would consider gaining ARP's advice (do they have a tech service?) and possibly bonding a stud in place so as not to stress the block thread again.
#9 _zooma355_
_zooma355_
Posted 18 June 2013 - 01:06 AM
Yeah thats where im at too, with sourcing a new block and the machining it would need im lookin at 1500 minimum so avoiding that option for as long as i can :)
 Gunna give that a crack terra, not likin it too much but will see how it goes, unless some1 else has a better option.
Cheers all
#10 _zooma355_
_zooma355_
Posted 18 June 2013 - 01:18 AM
So studs would put less stress on the thread?
#11 ls2lxhatch
  • 5,334 posts
Posted 18 June 2013 - 02:03 AM
A stepped stud will use a larger thread at the block end so you can drill and tap the block.
A stud can have more thread engagement (longer threaded section) and therefore they can be stronger than a bolt.
#12 neglectedtorana
neglectedtorana
  • 1,042 posts
  • Name:Tom
  • Car:LX Torana Sunbird
Posted 18 June 2013 - 05:55 AM
Hi Zooma Instead of a helicoil you could try a locking threaded insert They are stronger than helicoils and the sort of thing you can still do yourself with simple tooling. http://www.mcmaster....inserts/=n8hqr9 Sorry the link is from a company in the States but surely can be found in Oz not sure if it is suitable but well worth a look once you have decided if you continue or get it welded, studded etc Cheers, Tom
#13 _oldjohnno_
_oldjohnno_
Posted 18 June 2013 - 07:13 AM
The noise you heard was probably the deck around the bolt hole cracking/splitting. I'd be checking it very very closely.
#14 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 18 June 2013 - 07:38 AM
This is sad but may well be true.
The end head bolt holes are close to the bore and can and do crack to the bore. I have seen low performance engines repaired with a sleeve and thread insert but I wouldn't run that way.
Get the head off, have a good look and report back.
#15 warrenm
warrenm
  • 2,119 posts
  • Car:1972 LJ Torana
Posted 18 June 2013 - 07:40 AM
Have you got a pic?
#16 TerrA LX
Posted 18 June 2013 - 09:13 AM
PM Tiny if he is still doing the thread service kits, he maybe able to shed some light on a suitable repair, if the block is not cracked.
#17 _zooma355_
_zooma355_
Posted 18 June 2013 - 02:54 PM
 There seems to be only 3 or 4 threads left, doesnt really look like theres any deck or bore dmg. Although buggered if i know how i missed it!
#18 S pack
  • 15,736 posts
Posted 18 June 2013 - 03:29 PM
At a guess, you missed it because the thread was all there before you put the the bolt in.
Can't say for sure from those pics but looks to me like it is the original cast iron thread that has stripped not a helicoil.
No visible cracks so you might be in luck.
I would still advise taking it to a professional and get their opinion on the viability of a repair, and you could also discuss machining the head to inlet manifold faces to make your manifold fit properly.
Edited by S pack, 18 June 2013 - 03:31 PM.
#19 _Bomber Watson_
Posted 18 June 2013 - 06:58 PM
I agree that looks like it has just pulled the cast thread out.
Ive helecoiled head bolt holes before, and proceeded to put studs in them and torque them up to 90ft/lb.....
Ultimately that will cost you nothing to try (very little atleast) and if it fails six months down the track then get a new block and spend all the coin again....Might last forever :D
#20 _zooma355_
_zooma355_
Posted 18 June 2013 - 09:05 PM
yeah i assumed that but there was no thread material pulled out on the bolt thread so might have fallen straight down into the jacket. The manifold is in the shop now gettin a smidge taken off it cheers.
 Thx mate, any particular coils to use?
#21 ls2lxhatch
  • 5,334 posts
Posted 19 June 2013 - 12:16 AM
Have you checked the length of the head bolt?
It seems odd that only a couple of threads are damaged, maybe the bolt was too short to start with and that's what caused the failure.
#22 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 19 June 2013 - 06:19 PM
I thought the same, looks like you screwed one of the 4 inner bolts into that hole when it should have been about a half inch longer. Check your head bolts, there are 3 different lengths.
#23 Bernie
Bernie
  • 301 posts
  • Car:2 lx Hatches and 3 lx 4 doors
Posted 19 June 2013 - 08:22 PM
Use a Caterpillar  style thread insert repair .They are much stronger than helicoil and are keyed so they don't move .
Bernie
#24 _Mint_
_Mint_
Posted 19 June 2013 - 10:02 PM
Matt as the above guys have said its the bolt length..i used ARP head bolts on my recent 308 build..the ARP bolts come with a washer however using it makes the bolt about 10 mm shorter compared to the original Holden head bolt..so i didnt use the washers on all the long bolts
i did use the washers on the short bolts along the exhaust side of the head..the blind holes.. since these ARP bolts are longer than the original Holden bolt and were very close to bottoming
you may have inadvertantly stretched some or all of those threads and that one just went pop
Edited by S.S., 19 June 2013 - 10:15 PM.
#25 _oldjohnno_
_oldjohnno_
Posted 20 June 2013 - 12:44 PM
As Bernie says, use a keysert instead of a helicoil. The funny thing about all this is that the factory GM bolts are generally very high quality...
