Commodore axles in UC
29 replies to this topic
#1 _Lazarus_
_Lazarus_
Posted 03 July 2013 - 03:50 PM
I've had a bit of a search around here but haven't found the info I need. I did some research on offsets etc and for a cheap easy change to alloy 15" wheels I decided to buy some VP Calais mags. They have an offset of 28p. I was thinking that I could just get some VB / K rotors and get the stud pattern changed on the back.
I rang Diff Trans in Bundy yesterday and was told that the axle flange (?) is too small for a Commy PCD so we decided small Salisbury axles out of a VB / K would be the go. So can someone please tell me axle lengths of UC, and VB / K diffs please. It would save me pulling my axles out before a trip to the wreckers. The guy on the phone suggested that I get 2 short ones but I think it's better if I check first.
Thanks.
#2 76lxhatch
  • 7,213 posts
Posted 03 July 2013 - 05:49 PM
Salisbury diffs have equal length axles, no long and short like the later Borg Warners.
I can't tell you any lengths off the top of my head but I have a feeling the Commodore is around 100mm wider overall (remember the wheels are different offset) so it'd be completely wrong to make them work. Maybe you could grab some of the 28 spline ones and shorten them, they'd have more meat to do so?
I gather you are talking about just changing the axles rather than the whole diff? The latter would make more sense as the wheels wouldn't sit so far inboard but a lot of expense for not much gain.
#3 _Lazarus_
_Lazarus_
Posted 03 July 2013 - 07:12 PM
Thanks for your reply.
The offset of the VP Calais (IRS) wheels are 28p, the only Commy with this offset. The Torana is 30p or 32p (?) so the offset is not a problem ?
I just need a cheap axle with a bigger flange as I intend to go Borg Warner later.
By my calculations if the axles are the same length L&R then the difference should be about 45mm to 50mm each, allowing for track anf offset differences, probably not enough for resplining ? (15mm each side for offset and approx 60 to 70 mm track difference).
Aren't the 28 spline axles much thicker ?
What about if I get some fine spline HQ / WB banjo axles and have them shortened, resplined and redrilled ?
Is that an option ?.
#4 _Lazarus_
_Lazarus_
Posted 03 July 2013 - 07:16 PM
WB ute 6 cyl small Salisbury ?
#5 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 03 July 2013 - 09:16 PM
VK series 1 diff is about 65mm wider than the LX diff. WB 6 cyl axles can't be shortened as GMH only hardened them in the spline area. HQ - WB 1 tonner axles CAN be shortened, but good luck finding any.
#6 _Lazarus_
_Lazarus_
Posted 03 July 2013 - 09:51 PM
Hmmmmm.......
Thanks Vick.
So one tonner axles will definitely work with a standard UC diff ?
And that's my only (cheap) option ?
Maybe I'll have to email that Volvo wrecker again.....
But I'd rather use the rims I have if possible. One tonner axles won't be too hard to find up here if they're definitely gunna work.
#7 76lxhatch
  • 7,213 posts
Posted 04 July 2013 - 07:21 AM
Yes resplining will likely be a problem with Commodore small Salisbury axles.
Yes 28 spline axles are bigger and thicker, but I mentioned them because of the above, you may have enough meat to shorten and re-spline these to 23 spline. One tonner axles are the beefiest of the lot but again require shortening and machining to suit (plus they have HQ stud pattern).
I understand what you're saying with the VP wheels being a different offset to most Commodore but I think compared to many aftermarket wheels they probably won't fill the wheel arches that nicely, and again you're stuck with an oddball wheel that is hard to get (although admittedly there is a bit more in these offsets if you look at BMW). Personally if I was going to spend money on it I'd be doing something that gives me a much wider range of wheel options.
#8 TerrA LX
Posted 04 July 2013 - 09:03 AM
I really like this idea, plus VP calais mags look like corvette wheels. Let us know how you go with it.
#9 _Lazarus_
_Lazarus_
Posted 04 July 2013 - 03:06 PM
This is turning into a migraine.
Talked to the guy at Diff Trans again, armed with the above info. He's trying to talk me into a BorgWarner conversion now, but I can't afford it at the moment, and the way I drive I think the Salisbury is ample.
He said to pull one of my axles out and maybe get a small Salisbury axle from the wreckers and bring them in for him to look at. If someone had both lying around and could tell me the exact length difference it would save alot of trouble and frigging around.
He also said generic billet axles in either Ford or Holden pattern with a long spline cut into them which can then be cut to size are available on Ebay for around $150 each, which is cheaper than what he quoted me for machining down and resplining thicker axles.
Anyone know anything about these please ? Are they able to be shortened enough for a Torana ?
And can anyone tell me where I saw those pics on here somewhere of a Torana axle filled and drilled to Commy PCD ?
I think someone said that there was just enough meat for this, though it did look borderline, but I can't remember where I saw it.
Thanks again.
#10 _Lazarus_
_Lazarus_
Posted 04 July 2013 - 03:14 PM
Also  he said that an open wheeler diff only requires about 20mm of spline engaged to work ok. Can anyone tell me how long the splines are on a Commodore small Salisbury please ?
I may get away with just cutting them down.
I also think that this is a good idea for a conversion as the rear brakes are the same so  I can just use Commy drums.
Shame the wheels are only 6" but I can live with that. They do look cool and will go well with the more modern looking UC style IMO.
#11 _Lazarus_
_Lazarus_
Posted 04 July 2013 - 04:12 PM
And also the front should only require early Commodore rotors and HX / Z PBR caliper slides.
Can someone also tell me what exactly the UC Torana wheel offset is ?
There is a vast difference in information on various forums. 30mm is what I was originally led to believe.
#12 76lxhatch
  • 7,213 posts
Posted 04 July 2013 - 04:18 PM
I highly doubt you will have enough spline to get away with cutting them down. I really don't see any cheap and easy way to put Commodore axles in, and its kind of a waste spending too much on that. I have some diffs in my storage shed though, I can go down and measure them tomorrow to get a concrete answer on the widths (I can almost guarantee its not the answer you're looking for though).
If you're going to go Commodore stud pattern you may as well go discs as they're worth nothing these days but work fine.
The original wheel offset is kind of irrelevant, unless you want 5" to 5.5" x 13" wheels that sit way inside the guards...?
If you're not interested in spending money on a diff conversion perhaps it would be better value for money to find some different wheels.
#13 _Lazarus_
_Lazarus_
Posted 04 July 2013 - 07:34 PM
I am placing importance on offset because it will be a daily driver and we are only allowed an increase in track width of 25mm without an engineer's certificate here in QLD. The Commodore front rotors are apparently 10mm wider than HQ (Torana are supposedly very similar ?), so it's going to be pretty close but I can always use machined down and redrilled HQ rotors if I get pinged for it.
With the LNP (Liberal National Party) back in government here they well may resume mass roadside inspections, and I have also heard that older modified cars are often inspected in NSW, where I occasionally head to visit my oldies.
Would really appreciate your offer if it is no problem, but I really should have got my sh!t together today and rung the local wreckers before posting this as they may have some on the shelf or laying around after a diff centre removal.
Thanks for your offer of help and reply.
#14 76lxhatch
  • 7,213 posts
Posted 05 July 2013 - 01:36 PM
OK, at present the only pre-VN Commodore diff I have is a 4 cylinder one (small Salisbury), these have the 5x108mm stud pattern (basically the same as Torana, and use the same small brakes). Including drums its approximately 1515mm from wheel face to wheel face, I think the six cylinder ones may have been a few mm wider which makes sense with the different brakes?
The Torana diff is approxiately 1445mm wheel face to wheel face including drums. So that makes it at least 70mm difference, 30mm per side, which is way too much to cut the axles down and keep any spline.
I have a couple of UCs with 13x5.5" factory wheels on them, but I'm not 100% sure they are Torana - they kind of look like 4 cylinder Commodore to me but it would be strange if they all are. Maybe they are the same? For some reason I thought the Commodore ones looked different. At any rate they appear to be roughly 4.25" backspace with an overall width of 6.5" to the outside edges (5.5" is inside the beads). This would make them approximately 1" positive offset (25mm, very close to your Commodore wheels surprisingly). This was kind of hard to measure with the mess my shed is in though so take it with a grain of salt - couldn't see any stamped measurements on the wheels (they are probably there but).
The outside edge of the wheels is approximately 2.5" inside the guards on the UC sedan, 3" on the hatch (but the hatch could be bent).
#15 _mick74lh_
_mick74lh_
Posted 05 July 2013 - 01:55 PM
I know this is not related to the diff but another problem you might have if fitting these 15 inch Commy wheels to the Torana is fouling between the inside edge of the wheel rim and the upper control arm at the upper ball joint.
Don't know if you can mock up a measurement of it first but it might be worth doing before you go and convert the front to Commodore stud pattern.
A larger diameter wheel should clear fine though.
#16 _Lazarus_
_Lazarus_
Posted 05 July 2013 - 06:30 PM
Thanks again Kiwi.
According to this book I have the 4 cyl Commy VC model has a rear track of 1445 and the V8 1420. Unfortunately it doesn't have the six.
But the book is not reliable either.
I may have solved the problem today, just got to wait a bit longer to find out.
Fingers crossed......
#17 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 05 July 2013 - 09:17 PM
They clear fine, I've done it before.
#18 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 05 July 2013 - 09:34 PM
I should clarify that I used 15x6 steel rims with stock offset (+43) and Commodore front discs.
#19 _Lazarus_
_Lazarus_
Posted 05 July 2013 - 11:11 PM
Yeah I won't have this problem with the VP Calais IRS wheels but it's good info for others, thanks Vick.
#20 76lxhatch
  • 7,213 posts
Posted 05 July 2013 - 11:30 PM
A narrower track would have to be from wider wheels with more positive offset, the diff itself won't be narrower.
Let us know if you do find a simple solution.
#21 _Lazarus_
_Lazarus_
Posted 06 July 2013 - 01:24 PM
Ok. minor update.
Bought some fine spline LH / X axles 'professionally re-drilled' off ebay. $50 bucks a pair, same flange diameter as UC I gather (?) but much cheaper than finding someone willing to do mine so couldn't resist.
The diff will not be coping with anything more than a warm 202 manual and 225 max tyres. Plus I am a very sympathetic driver.
Do they go straight in with no minor shortening or machining and which bearings should I use, if they are different ?
I'm presently waiting to hear from him after I sent a message this morning as ad said pick-up only. I haven't had to organise interstate 'pick-up only's' before so would appreciate any advice or help here, if necessary. Willing to provide grogs / cash for services rendered. They are at Narre Warren Vic somewhere. Will know more when I hear from him.
Hopefully they will arrive in good nick ready to go.
Fingers will remain crossed for some time yet, it seems....
#22 _Lazarus_
_Lazarus_
Posted 06 July 2013 - 06:24 PM
And thanks to Quag for the 'go for it' advice yesterday.
#23 76lxhatch
  • 7,213 posts
Posted 06 July 2013 - 08:50 PM
UC Salisbury (non disk brake) and LH/LX fine spline Banjo axles are interchangeable, same bearings etc. Obviously coarse spline don't fit the Salisbury unless you want to downgrade it by changing the side gears
#24 yel327
  • 13,714 posts
Posted 06 July 2013 - 08:53 PM
UC drum brake axles are the same as LH-LX, only snag will be if they are disc brake axles.
#25 _Lazarus_
_Lazarus_
Posted 07 July 2013 - 10:19 AM
Thanks guys.
This site is fuggen awesome.
