atm I'm looking in another thread how to get the starfire engine balanced right out so it stops its rattling. but I cant really see me stretching the capacity beyond a 2.3l.. and a 2.3l 4 cyl is a pretty big 4 without balance shafts.
So I've been thinking for a while, that one way to make a genuine 'holden' 4 cyl is to cut down a 308. cut and shut the heads, crank and block. even with cutting down a 5l it still will only give a 2.5l which isnt radical....BUT, what If i cut down a 383 stroker crank - to give a 3.1l four.
Nice I hear you say? not too bad, but being a 4 cyl, it would have balance issues as any big 4cyl. unless balance shafts could be put into it. BALANCE SHAFTS? I say? in a holden v8? I started to look around, and the buick 3.8l v6 has one- yes ONE balance shaft - and its fitted in the valley between the heads. Looking at the picture of the 3.8l v6 I can see how a holden 'v4' could be machined to accept a (rather short) balance shaft.....
Hey and while I'm dreaming I could buy a rather expensive come alloy holden block and some alloy heads to bring the weight RIIIGHT down. with big holden breathing heads, a 3.1l v4 would be so short in the engine bay it might improve the weight distribution of.... anything its fitted to!........
