Hai guys, Im getting ready to purchase a brown davis 120L drop tank for my LH. Basically wanted to know some things about them before i get it.
First off, is it legal in WA? http://www.canberrat...droptank_2.html states that you will not need certification from an engineer in WA - is this the case? last thing i want is to get it here, on the car and driving then get sticker'd...
Second, mounting. I know they mount on the chassis rails, but do the original tank supports need cutting and moving to a new position..? im sure, once the tank is in my possession, i can trial mount it but pre-info is always handy...
Thirdly, will i need to retain my existing filler and pickup/gauge sender unit or does it come with one?
And finally, to those in WA, did you go straight thru Brown Davis to purchase you tank or did you go thru a certified Davis Dealer (Armadale 4WD)..?
Before you say "search button.." i did that and got nothing.
<3 Josh
