Diff ratio advice for engine & gearbox combo
18 replies to this topic
#1 _Callen_
_Callen_
Posted 29 July 2013 - 11:32 PM
G'day all,
I'm rebuilding my banjo rear end and I'm having a dilemma over what centre ratio to put in as I can't really be f****d changing it if its not what I expected.
I'm running a 202 with an M20 aussie 4 speed but I haven't actually had a car with a munchie 4 speed before so I don't have any idea how it effects the setup but I've got a 3.08, 3.55 or even a 3.9 if needed, so was after peoples experiences with that setup/diff ratio combos.
In my experience I've had the following but both were 3 speeds so I'm trying to work out how a 4 speed would effect things:
- 202 with trimatic and 3.08 diff- Not bad off the line but responsiveness at highway speeds (100kmh +) was average and I always felt the engine seemed to be a bit overworked due to 3rd gear topping out.
- 186/192 with crashbox and 3.9 diff- Killed it off the line but was terrible at highway speeds (well obviously) and it struggled to maintain 60mph
I'm leaning towards the 3.55 as I would like to have some punch down low, but how difference does a 4 speed make at highway speeds? and would it make a huge difference with a 3.08 opposed to the 3.55?
- I'm not concerned about economy as it wont be a daily driver
- I would like to do a fair bit of highway driving so be easy to maintain 100k plus without having to push it along too much, but still be fun to drive around the city.
Any insights anyone?
#2 _LS1 Taxi_
_LS1 Taxi_
Posted 29 July 2013 - 11:59 PM
3 and 4 speed both have 1:1 ratio in top gear so no difference. I'd go the 3.55 also.
#3 Ice
  • 15,128 posts
Posted 30 July 2013 - 12:10 AM
Highway driving and 3.55 dont go together that well your engine will be revving its arse off at 100 kph
3.08 would be better for highway driving imho
#4 S pack
  • 15,549 posts
Posted 30 July 2013 - 12:11 AM
^^^ Agree, however if you are going to do a fair bit of highway driving then I wouldn't go below a 3.36.
Years ago I changed up from a 3.36 to a 3.08 and was much happier with the revs at 100kmh.
#5 Ice
  • 15,128 posts
Posted 30 July 2013 - 12:13 AM
More legs with the 3.08 and 4 speed
#6 EunUCh
EunUCh
  • 2,761 posts
  • Car:japos
Posted 30 July 2013 - 08:34 AM
Wheel/tire size plays a fairly important role in what ratio to run as well,usually most engines were run at peak torque
or just above at 60mph.
This calculator might help a bit.http://www.advanced-...Size/index.html
#7 BIG KEV
BIG KEV
  • 1,202 posts
  • Name:Kevin
Posted 30 July 2013 - 09:55 AM
It all depends on what kind of driving you intend to do .....3.08 is a good all rounder ....but if you want more go down low go 3.36 or 3.55 but no good for highway driving......read above post sounds like most guys here have been down this road before ......good luck
#8 _Lazarus_
_Lazarus_
Posted 30 July 2013 - 12:19 PM
3.08 for a Torana. They're light enough to cope around town. Much better for highway driving.
For a HQ - WB six cylinder the 3.36 is probably a bit better if you don't want to hold up the traffic around town.
#9 _stretchlc_
_stretchlc_
Posted 30 July 2013 - 01:07 PM
I've never found 3.36 or 3.55 ratio's to be a pain to drive on the highway................3.9's on the other hand, Yes definately!
#10 76lxhatch
  • 7,158 posts
Posted 30 July 2013 - 03:16 PM
Exactly, I don't see any mention of this...?
Factory 13s (assuming we're even talking about a Torana) will be quite a bit different to say a set of 17s or 18s with bigger rubber
#11 _Sir LC_
_Sir LC_
Posted 07 August 2013 - 09:52 AM
Check out this, its pretty accurate and takes into account your tyre size, gearbox ratios, final ratio etc.
Have recently used this to help me decide between a M20, M21, Celica, Supra box, and final ratio.
http://locost7.info/gearcalc.php
#12 caterham2
caterham2
  • 348 posts
  • Location:Mansfield North East Victoria not the other one in QLD
  • Car:Ford Focus RS AWD Gone over to the dark side .. Mercedes-Benz SLK350 Ford Cortina 2 door MK1 Twin Cam
Posted 07 August 2013 - 07:43 PM
G'day all,
Callen, I have tried ALL the ratios available in my car............  LJ XU1, engine hp 250, Bathurst ratios  in box ( dare I say it, a verified Bathurst build former group C  car) used for all sorts of things including hillclimb events. With this gearbox and very tall first gear a 3.08 is near unuseable on any sort of incline when starting off due to cam characteristics, 3.9 buzzes like mad at highway speeds but its lots of fun, 3.36 and 3.55 tried and found to be good all round  on the road, I will put the 3.36 back into mine when I get round to it, I think it was the best combo bearing in mind Victorias 100kph limit, but maybe with your lower first gear 3.08 would be a chance.
#13 N/A-PWR
  • 9,602 posts
Posted 07 August 2013 - 07:48 PM
Stick a 2.78 LSD in it with a M22 Box and Skinny tyres. Dave I
p.s. The M22 (6cyl One Tonners only) has a 1st gear ratio of 3.74
Edited by TORYPOWER, 07 August 2013 - 07:59 PM.
#14 N/A-PWR
  • 9,602 posts
Posted 07 August 2013 - 08:16 PM
Hi Callen,
As said in Post #13 - You will start off like a M20 ( 3.05 1st ) with a 3.55 diff and the rest is History. Dave I
p.s. Fully Worked Motor can handle the gear ratio spaces of a M22 and 2.78:1 LSD Banjo Diff
p.p.s. tried and proven in which is my new build
Edited by TORYPOWER, 07 August 2013 - 08:24 PM.
#15 _Callen_
_Callen_
Posted 01 October 2013 - 10:21 PM
Thanks for all the replies everyone, all very useful info and some obvious things that needed to be pointed out to my dumb ass (top gear in a 3 or 4 speed are both 1:1 ratio!)
#16 _Callen_
_Callen_
Posted 01 October 2013 - 10:26 PM
Am leaning towards to 3.55 after all consideration, but would be good to get my hands on a 3.36 me thinks. 3.08 I fear may be a bit lame
#17 _judgelj_
_judgelj_
Posted 01 October 2013 - 10:53 PM
I'd say 3.36 having driven 2.78 upwards. Perhaps finding the difference between 3.36 and 3.55 will help you decide?
#18 _LH8VD69_
_LH8VD69_
Posted 01 October 2013 - 11:02 PM
Have the best of both worlds mate. Run a 3.36 diff with a Toyota 5 speed. You will have low down and a bit of legs for the highway !
#19 _Callen_
_Callen_
Posted 02 October 2013 - 04:25 PM
Exactly, an overdrive 5th gear of less than 1:1 ration would be sweet
