Rochester Quadrajet???
_oikurtman_
, Jun 27 2006 10:07 AM
8 replies to this topic
#1 _oikurtman_
Posted 27 June 2006 - 10:07 AM
Trying to get the 253 in working order before dropping it into the LH...
Took the rochester off because the primary butterfly shaft was ceased. Managed to uncease it and have both primary and secondary throttles working, (not sure if correctly though). Problem is, i can't remember how the linkages for the chokes connect back up to the primary shaft. Or where all the vaccuum lines go... Any ideas? pictues maybe?
Posted 28 June 2006 - 09:23 PM
post a picture of what you have and I can guide you on what to do
Posted 29 June 2006 - 02:45 AM
if you having that much trouble with stuck shafts and the like, i'd hate to see what else could be wrong with it (stuck needle and seat, dead float etc etc) you be better of with a reco unit, sounds like your one is going to give you no end of trouble, even if it does run.
try hume performance at warick farm, the guys there offer free advice when approached with a friendly attitude.
i suggest next time borrow a digital camera and take photos, it costs nothing and erase them once finished, wouldnt be the first time ive done it, especially with new model cars, pipes and sh#t everywere.
Edited by ALX76, 29 June 2006 - 02:48 AM.
Posted 29 June 2006 - 02:56 AM
A good carby overhaul kit usually comes with a parts diagram which are a great help at getting the things back together.
#5 _rorym_
Posted 29 June 2006 - 09:23 AM
PM Louie (purpleLC) on this forum, he owns Carb Reconditioners at Campsie I think it is...Hes the guru to fix your current carb.
Posted 29 June 2006 - 11:37 AM
^he sure is
#7 _oikurtman_
Posted 30 June 2006 - 07:57 AM
hey thanks for the advice fellas...
right when i was going nuts over this carby, a mate of mine rocked up and told me i could have his worked red 253... which just so happens to have a working rochester on it!! (well, the throttle butterflys move anyway)
Posted 04 July 2006 - 04:11 AM
^mmmmm man i just had a thought, you not trying to operate the carb incorrectly are you, cause the top butterflys only open with engine vacuume, the bottom ones work like a mechanical secondary, together they function to lift the jet rods to allow fuel flow.
just a thought.
just a thought.
#9 _Yella SLuR_
Posted 04 July 2006 - 07:50 AM
The GMH HQ Manual 4 has all the rebuild/adjustment info for the Quaddy. I have a rebuild kit diagram, but depends which quaddy you have, there are over 20 variations of the Quadrajet. Also, I have no scanner, old one died.
Basic piping is auto choke vacuum off the rear, mechanical advance of the front right (looking at the carb from the front), fuel top centre on the front, and to the cannister centre bottom (under the fuel line). That should be all the tubes, brake vacuum comes off the manifold.
Edited by Yella SLuR, 04 July 2006 - 07:53 AM.
