Chassis number location
#1 _RobLX_
Posted 30 June 2006 - 05:59 PM
I have just had my car checked over for a blue slip in NSW, all good, except that the inspector could not locate the chassis number on the chassis, I had a look and haven't be able to find it, so I have two questions.
1 Does anyone know where the chassis number is stamped into the chassis, is it in a standard location? and
2 If there is no number stamped what do RTA in NSW do about it.
I'm thinkinh that it has probably been painted over
Rob
#2 _RobLX_
Posted 30 June 2006 - 06:00 PM
Posted 30 June 2006 - 06:09 PM
#4 _Herne_
Posted 30 June 2006 - 06:11 PM
(front drivers side)
Someone else will be able to answer what NSW does about these things.
Herne
Edited by Herne, 30 June 2006 - 06:11 PM.
#5 _SLR5000_
Posted 30 June 2006 - 06:29 PM
Find part of the number & get some fine sandpaper & rub over it will reveal you chassis number.
If you cant see any number in place I have specified, try the fine sandpaper in that area I am sure it will be there.
let us know how you go
#6 _RobLX_
Posted 30 June 2006 - 06:30 PM
checked the area, there is nothing, but is has been repainted, so I guess I'll get to find out the answer to the second question.
RobsLX
#7 _doucmyuc_
Posted 02 July 2006 - 07:38 PM
try stripping it back to bare metal in that section.Thanks
RobsLX
I know on the uc hatch i have here the engine bay has been painted many times, and with primer, layers of paint etc it fills in the stamping.
It will almost gaurentee be there unless for some reason that section has been cut out.
Posted 02 July 2006 - 07:58 PM
i say SMASH because thats litterally what ive seen some number jobs come out like.
#9 _keith1962_
Posted 02 July 2006 - 08:08 PM
the original number had been ground out by car thieves but
the Victorian police place a body number on the rail in front
of No 3 spark plug(v8)
cheers Keith
#10 _RobLX_
Posted 03 July 2006 - 08:25 PM
thanks for the replies, you had me in the right area, it wasn't until i removed the overflow bottle next to the radiator that I found it.
All good, the Blueslip is done.
The number is forward close to the radiator.
Again thanks guys
Posted 12 July 2006 - 05:21 PM
It does look like the inside lip of the rail has been bent over to fit a wider radiator though. Im guessing its on that part which has been bent over?
A bit awkward to get to without taking the radiator out.
