I'm trying to get the front wheel offset on a standard LH confirmed for once and all.
Ignoring L34 as it is apparently -6.35mm (-1/4") (http://holdenpaedia....m/Stud_Patterns) due to the different caliper / steering arrangement
For the rest of the square bodies, unmolested steering and brakes, Gregory's manual says +28mm.
This thread cites +19mm and 28mm and different depending on rim size
http://www.gmh-toran...fset-confusion/
This thread also cites different values depending on wheel size
http://www.gmh-toran...rana-commodore/
So which is it
And is the offset (measured between centreline of wheel and hub face) apparently different depending on rim size? Does this mean if we replace with say a 17x8 even if the rolling diameter is maintained (~600mm??), will 19mm offset no longer be correct geometry?
Edited by Lima31, 07 November 2013 - 12:17 AM.
