UPC brake upgrade 330mm helppppppp!&&
39 replies to this topic
#26 _UFO304_
_UFO304_
Posted 17 March 2014 - 07:48 PM
What I would like to know, is who has successfully fitted this kit?
Ive currently got the old HQ stub axle setup with Girlock calipers bolted to the rear of the stub.
There are 2x kits
one is hubs and brackets, the other is a whole kit.
Does anyone have any pics of what had to be ground or machined?
I had to grind my K-frame when I put the HQ setup on, years ago, but that is because the calipers are on the rear, and not the front like a standard torana.
#27 SmacT
SmacT
  • 907 posts
  • Name:Sam
  • Car:LX 4dr 383, TKX, BW
Posted 21 March 2014 - 09:34 PM
Just save a bit more and go Hoppers Stoppers I reckon. They fit, aftersales service is awesome and the quality is great.
#28 Lima31
Lima31
  • 874 posts
  • Name:Lee
Posted 22 March 2014 - 01:34 PM
+1
#29 _nemo355v8_
_nemo355v8_
Posted 17 April 2014 - 10:44 PM
There are 2x kits
I have fitted the UPC 330s to my LX, cant see what every ones issue is. simply grind the required clearance into the top arm and weld in some 1/4 round bar into the top arm above
where you relieve the top arm.
People mod the crap out of other stuff on there cars so I cant see the issue to take a small notch out of the top arm then reinforce it.
Been on my car for years and other than notching the top arm they are a straight bolt up
Edited by nemo355v8, 17 April 2014 - 10:46 PM.
#30 _UFO304_
_UFO304_
Posted 19 April 2014 - 11:03 AM
Have you got pics?
#31 _LS1 Hatch_
_LS1 Hatch_
Posted 19 April 2014 - 11:12 AM
Probably because they are sold (initially) as a 'bolt on' kit, and chopping up a control arm is far from bolt on, and many people would shy away from modifying suspension components I would imagine ?
#32 _LXSS350_
_LXSS350_
Posted 19 April 2014 - 09:33 PM
There is absolutely ZERO need to cut up your Torana to fit 330mm discs and calipers unless your brain dead and don't know what you are doing. Cutting up your suspension arms is just totally unnecessary and can only be dangerous and frowned upon when gaining registration or permits (pits). Mr Spares, Tony Edwards, UPC only do this because he doesn't give a hoot about doing something properly and will only lay any blame on the purchaser of his so called bolt on kit.
This has been regurgitated not only in this forum but in many other forums. The guy has a clear history of taking your money and under delivering and leaving the purchaser well out of pocket. With so many people saying similar things about  Mr Spares, Tony Edwards, UPC its clear that once warned its up to the individual.
I had never dealt with him until a few years ago but after calling Mr Edwards (for a close mate) in an attempt to sort his brake order I learnt all about this person and his company. What an absolute tosser .... he couldn't understand why his kit wouldn't bolt up. When I told him why he said my mates torana must be different from other LX's and not standard (what bs). I said well its the same as the other 5 x LX toranas that I have here? LOL
I would rather have Syphilis than ever deal with that loser ..... he has no idea.
#33 _UFO304_
_UFO304_
Posted 21 April 2014 - 10:52 AM
Well its pretty clear what the consensus is . . . . . . . . . . . . .
#34 _Hazard_
_Hazard_
Posted 26 February 2015 - 09:46 PM
I've ordered one of these kits for my LH, spewing about it now from what I'm reading. If these use ve calipers does anyone know if the ve 4 piston brembo's are smaller than the stock 2 piston calipers? They look to be not as wide but I haven't been able to compare them side by side.
#35 hatchssv8
hatchssv8
  • 351 posts
Posted 22 April 2015 - 11:31 PM
Hey Hazard
Did you end up fitting the 330 kit successfully?
Cheers, Max
#36 Holdenbn74
Holdenbn74
  • 147 posts
  • Name:Brendan Nichol
  • Car:LH
Posted 23 April 2015 - 07:56 PM
I used the smaller kit for 15" wheels and was pleasantly surprised how it all worked out no issues. Definitely wouldn't go near the 330mm ones ☺️
#37 _UFO304_
_UFO304_
Posted 24 April 2015 - 08:48 AM
Have you got a pic?
#38 hatchssv8
hatchssv8
  • 351 posts
Posted 25 April 2015 - 12:36 AM
Don't think anyone that's got a UPC kit has taken any pics.........Ken keeps asking but.....nada
#39 UC308Hatch
UC308Hatch
  • 119 posts
  • Name:Ron McNab
  • Car:UC Torana Hatch
Posted 02 July 2015 - 07:04 PM
Hey Guys, I have a UPC 330 mm kit & got it to work. I have perviously answered this here
http://www.gmh-toran...post__p__875156
I brought it about 6 years ago, in hind sight I should have sent it back but being 7 year build I didn't discover the issue until 4 years after purchase. Not to be deterred I made it work without cutting the top arm or k frame.....
Edited by UC308Hatch, 02 July 2015 - 07:07 PM.
#40 _Hazard_
_Hazard_
Posted 28 November 2015 - 10:09 PM
Hey guys, I also screwed up and got one of these kits I used HQ stubs with Harrop arms. Like everyone else the caliper hits the uca but I was wondering if anyone has tried using the Ve brembo caliper instead? From what I can tell they don't seem as bulky on the back, any info would be great before I fork out a grand for a set to see if they'll work. Cheers
