To put it simply if you want to make dcoe's work the way they were designed to then you need a 12 port head. This could be a true 12 port or a 9 port with a 12 port conversion.
These 2 options require different manifolds so pick the the head type to suit your existing manifold.
Dcoe's should run one barrel per cylinder. Each carb is really 2 carbs in the one body that share a common float bowl and spindle.
Fortunately on a street car you'll have no restrictions on head design that some classes of racing having to work within.
I know where you're coming from but I'm not sure it's so black and white as that. Yes, a 12 port arrangement makes more sense but the reality is that it's a lot harder to get 200cfm+ from a 12 port than it is from a 9 port. The 12 ports can be made to run very very well but usually if the absolute maximum in peak hp is the goal then it's easier to get the flow from a 9 port. Having said that I'd have no hesitation in running a 12 port on a street/strip motor. The other thing to keep in mind is that the OP already has 9 port manifolds.
DCOES should run one barrel per cylinder..
It might be more accurate to say they were designed to run one cylinder at a time per barrel, which sorta-kinda fits the 9 port setup. But I agree, the triple DCOE setup on a 9 port is ugly and not ideal but you have to weigh this up against the flow advantage of the 9 port. I'm sure that with some development work a 3 throat arrangement (eg. HSRs or even VMs) could be made to beat the triple DCOES on a 9 port.
Just remember that if you do go 12 port it's gonna need more throat area and more cam. And I've never seen a 9 to 12 port conversion that worked.
Edited by oldjohnno, 11 October 2015 - 07:01 AM.
