Help with new lincoln mig
Posted 26 December 2013 - 07:31 PM
Its brand new came with all the accessories like gas hose , regulator etc
Now im running 0.8mm solid wire with 0.8mm tips. Ive tried 0.6 wire also. No matter what i do, adjust wire speed / amps, its producing terrible welds
Ive tried adjusting the argon / oxygen to 10litres per minute all the way through to 30litres per minute... Still nothing changes. The mix is argon shield light from boc (75% argon 25% oxygen)
Im about to flip my wig , i can hear the gas coming out of the tip, but it seems its not doing anything. Please help
Also the arc seems to splutter and carry on a bit aswell. The test welds are in a new piece of 1mm sheet metal image.jpg 218.56K 3 downloads
Posted 26 December 2013 - 07:56 PM
Theres no gas at your weld.
Get your torch closer.
5 mm away should get you going.
If that's not it turn your wire to zero and hit the trigger and cover the nozzle with your hand to see if you can feel the gas.
If you cant feel it, theres no gas and there is a problem with the torch. Could be the gas line has popped off inside the torch. Could be an incorrectly fitted nozzle, could be the wrong welding tip.
Post a close up front 3/4 pic of the nozzle if you like, it might help diagnose the problem.
Post a pic of the regulator while you are pulling the trigger while you are at it.
Posted 26 December 2013 - 08:16 PM
i have just bought the same mig and am hoping to fire it up in the next couple of days. might be a silly question, but have you swapped the nozzle from the plastic one that comes fitted on the gun for the gasless wire?
#4 _mikecatts_
Posted 26 December 2013 - 08:27 PM
Matt...Try using a .9 tip with the .8 wire...I use argon with 7% oxygen... 25% oxygen will cool the weld... and have no penetration as your welds are doing... Hold the tip about 5-10mm from job.
Mike
Posted 26 December 2013 - 08:29 PM
Where you are welding is it windy? Close to a fan? Maybe try another bit of steel , it might be just my monitor but the colour around the weld doesn't look right, too yellow like it is zink or something.
Posted 26 December 2013 - 08:45 PM
I like Stingas theory a lot.
I didn't know they came that way.
Let us know how you get on.
#7 _Viper_
Posted 26 December 2013 - 09:29 PM
25% oxygen? Normal atmosphere only has 20.9% oxygen! Was that a typo? If not then you have the wrong bottle as Argoshield light only has 3.1% oxygen, 91.9% Argon and 5% Carbon dioxide
And would certainly cause the issues that you are getting.
#8 _mikecatts_
Posted 26 December 2013 - 09:38 PM
Just had a thought... Some welders come with sample wire.. Your not using the "gasless" wire??????
this is how mine was set up craig, out of the box(though mine is the 180c also) guessing they all come that way
http://www.google.co...0&tx=103&ty=106
Posted 26 December 2013 - 09:52 PM
If they are set up for gasless the polarity will be the wrong way round .
Posted 26 December 2013 - 09:59 PM
yep your right, also another thing that needs to be changed for gas
Posted 27 December 2013 - 02:32 PM
does look to be a gas flow problem, check all the lines, check O ring in the torch connection to welder, around 18lts/min should do the job.
The argo light is ideal for panels.
You got .6 rollers in also?
Posted 27 December 2013 - 04:43 PM
Posted 27 December 2013 - 04:46 PM
#15 _ryan350_
Posted 27 December 2013 - 10:07 PM
just read the instruction manual to find out what leads go onto which ie - + . When i first got my lincoln 180 i had a similar problem. decided to read the manual and found that the leads where set up for gasless welding. Swapped them around and she was sweet after that. There a great little welder!
#16 _2DR_
Posted 30 December 2013 - 12:00 AM
i have the same model great welder , as has been said might be using wrong wire or polarity is wrong way round
