I need some measurments for some rubber brake hoses off an LH Torana.
1- Front rubber brake hose
2- The rear rubber brake hose from the body to the diff
Brake Hoses
LHEFI
, Jul 05 2006 03:32 PM
6 replies to this topic
Posted 05 July 2006 - 03:32 PM
#2 _MAWLER_
Posted 05 July 2006 - 06:09 PM
Are you talking about length or diameter?
Posted 05 July 2006 - 06:50 PM
Just go to your local brake/clutch centre they will look up the hoses and have them in stock.
Like $20-30ea for the made in INDIA ones.
Posted 05 July 2006 - 07:30 PM
I'm after the length. It is to get some braided ones made up.
Posted 05 July 2006 - 10:27 PM
bbbbbraided brake hoses, carefull.
Posted 05 July 2006 - 11:00 PM
LH front hose is part # H1103
Rear hose is part # H1104
If your hose maker doesn't know that.....and can t get the lengths from catalogues then chances are they aren't ADR spec hose makers
Anyway
Fronts are 432mm
Rear is 305mm
3/8" UNF female one end convex seat (with circlip groove) and 3/8" UNF male at the other end. (concave seat)
Anyway
Fronts are 432mm
Rear is 305mm
#7 _rorym_
Posted 07 July 2006 - 07:52 PM
I have run braided lines on all my race and road bikes and have them on the XU1 V8...never looked back...no pump up on the pedal/handle.
