Hi Everone
Just had a few questions about this diff i am converting, any input would help thanks. So I have the 9" pumkin with the tubes removed. I have the tubes and brakes off a VN which i am going to weld to the pumkin once shortened to correct lenth. The centre is 28 spline. I have two nine" axles on the way which i planned to shorten and adapt to the VN brakes. My first question being, the axles that came out of the VN diff are also 28 spline and fit in the 9" centre perfectly. They are quite a chuncky axle is there any reason they connot be used?? My other question was besides the calipers hitting the shock, which i plan to swap backing plates around and mover calipers to the front and the hand brake cord adaption, what other problems will i come up against??
Would love some insght into this from all you torana fan that have been here before!
Sam
