Please don't take this as a personal attack, just trying to justify shelling out for the kit you posted, but I HAVE height adjustment with OEM type gear now (uprate springs/shocks), I set my ride height and forget it.
If you run the QA1 shocks with stock arms then they are not much more expensive than a decent set of shocks and springs.
Adjusting the ride height with the QA1 shocks takes a couple of minutes. Pulling out the springs and sending them off to be reset or changing springs is not quite as convenient.
Getting springs reset to adjust the ride height is always a little hit and miss. Adjusting the height with the QA1 shocks you can get the exact height you want every time.
I need one height for registration and then I would like to lower it a bit for aesthetics. When I drive on country roads to visit my brother I will probably raise the car back up to stock height or maybe even a little higher.
Edited by ls2lxhatch, 12 February 2014 - 12:27 PM.
