Steering
#1 _youngy_11_
Posted 08 July 2006 - 07:15 PM
I have got the front end loosened but aren't sure how to dismantle the steering column??
Also what is the best way to get the brake hoses off the front callipers, because i tried undoing the nut arrangement in the top of the wheel arch where it is changed from the flexible hose to the metal pipe hose and in the process twisted the metal pipe and broke it .
thanks ryan
#2 _youngy_11_
Posted 08 July 2006 - 08:08 PM
ryan
Posted 08 July 2006 - 08:15 PM
Posted 08 July 2006 - 09:17 PM
#5 _youngy_11_
Posted 09 July 2006 - 08:26 AM
thanks ryan
#6 _Flamenco_
Posted 09 July 2006 - 11:38 AM
To take it out of the car you just need to undo four bolts at the firewall where the column goes through, 3 bolts under the dash where the colapsible bracket is, the cotter pins need to be removed where the flexible coupling is and lastly the plugs for the indicators etc need to be unplugged before removing the whole column...
Without the proper tool for the cotter pins (which is hard to come by!) FastEH's method would be about the best....
#7 _youngy_11_
Posted 09 July 2006 - 12:42 PM
I am away for the next few days so will have another go when i get back.
Anyone else have any other tips???
ryan
#8 _user asked to be removed_
Posted 09 July 2006 - 03:03 PM
Does it just callapse? What if you were in a car crash? Or isn't it like that?You should never hit anything in the steering column with a hammer, particularly the shaft and associated bits. Blunt force on this bit will collapse the shaft.
Posted 09 July 2006 - 05:41 PM
If anyone needs..I have a good steering shaft and outer tube from a UC
Posted 09 July 2006 - 07:36 PM
This idea will work, i tried it this afternoon, mine felt a little sloppy so i put a small G clamp on it with a socket bigger than the nut and pushed it in enough to stop the slop.You could try a small G clamp
Took the clamp off and gently tightened the nut.
Had moved it enough to get a full turn!
You should be able to do the reverse to take it out.
Paul
Posted 18 July 2006 - 12:39 PM
Dragged out my spare column last night and tried with the G clamp and a nut to push against.This idea will work, i tried it this afternoon, mine felt a little sloppy so i put a small G clamp on it with a socket bigger than the nut and pushed it in enough to stop the slop.You could try a small G clamp
Paul
Worked a treat, this cotter must have been the original install.
After 1/2 a turn the thing made a loud bang and the cotter was out, no damage to the cotter, its thread or the nut.
Point about the nut is i left it on, level with the end of the thread to protect it and give a decent surface to push on.
#12 _youngy_11_
Posted 18 July 2006 - 05:51 PM
So we are going to soak the pin in penetreme and see if that will lossen them up.
Yes thats good practice to have the nut level with the pin because you can always replace the nut easily but the pins from what i have read are like $20 lol.
My dad also got another one of the pins out by using the hammer. But he recons he gently worked the pin out with the penetreme a block brace and light tapping by the hammer. I swear those pins in my column must have been way tighter/seized than yours but i know for now. lol
Thanks Heaps
Ryan
Posted 18 July 2006 - 09:03 PM
im in the middle of removing my steering column. I have unbolted the whole column the only problem i am having is removing the column either at the knuckle or at the coupling. There is a bolt that goes through the steering knuckle with a circular head and a nut on it. I have tried gently hitting this but it will not budge. Should i attempt to take it out from the coupling? i havnt played with these before and am unsure of how to take it apart. What is the best way to free the column down in the engine bay? (kunckle and coupling)
Posted 18 July 2006 - 09:52 PM
Posted 19 July 2006 - 12:41 PM
#16 _Yella SLuR_
Posted 19 July 2006 - 02:00 PM
They are always nice and firm at the best of times, and alway a pain to get out.
Edited by Yella SLuR, 19 July 2006 - 02:02 PM.
#17 _youngy_11_
Posted 19 July 2006 - 03:58 PM
Anyway all knowledge.
Ryan
