Just took my 355 LH Torana for a drive to clear out the cobwebs. Started up no problem, drove for 20mins & parked for half hour before heading for home, again, started no problem. Arrived home & turned the car off so I could unlock the gate, open the shed & put it away.
It would not start, barely cranks over. The car runs a near new 85A Bosch alternator & last time I tested it in the car, it was charging around 14.1 on the amp meter. The factory SL/R amp gauge reads just over half, so I'm guessing the charging system is working as it should. Being a fairly hot day & the fact the engine is far from stock, it tends to run on the hot side when cruising at low speed & stop/starting in traffic, so I ran the twin 12" thermos to keep it around 80C temp.
Now, I'm assuming that running these fans for the drive home has drained the battery, is this the likely scenario? I thought an 85A alternator would be plenty enough for the job, there is no big stereo etc in the car.
Could it be the fans are drawing more power than the alternator can cope with? The only other scenario I can come up with is the battery is past it's prime, it is a couple of years old, but has not seen much use in the car & I always disconnect it when the car sits for extended periods.
Any advice would be greatly appreciated.
