Radiator Support dimensions for LH-LX Torana.
5 replies to this topic
#1 _Liam_
_Liam_
Posted 22 April 2014 - 07:52 PM
Hey guys I've realised that I hadn't actually posted these up which is stupid.
And once it is made and fitted to the car.
Bits and piece may need to be trimmed and tapped but for the most part will suffice for most.  Also the reinforcing I just cut a notch into the support and welded the brace in there.
Hope this helps someone.
#2 _LH mike_
_LH mike_
Posted 15 May 2014 - 05:29 PM
thanks for posting this up, have you got a larger pic of the dimensions , i cant quite read them.also any pic's of the finished product? cheers
#3 _markelldawe_
_markelldawe_
Posted 17 May 2014 - 10:36 AM
I second that, great job on putting it up, however alot of the measurements are very hard or unable to be read. Even if you just list the measurements it would be easy to work out what goes where.
#4 N/A-PWR
  • 9,595 posts
Posted 17 May 2014 - 12:00 PM
I expanded it,
and you can use a rule to work out the sizes, from what we can read:-
Attached File  RadSupportExteriorSkin (1).jpg   32.73K   75 downloads
Click on image
Edited by TORYPOWER, 17 May 2014 - 12:07 PM.
#5 _Liam_
_Liam_
Posted 25 May 2014 - 02:45 PM
Shit sorry guys didn't realise it was so bad to read.
OK, measurements are as follows; all measurements were taken directly from the original in mm.
HORIZONTAL Measurements
Top Orange tab,
195,58,52,162,93,93,54, 55, 195
Top Yellow tab,
220 for both
Bottom Yellow tab,
Overall measurement of 1010, the cut out starts 230 mm from the tapered fold, is 145 mm long.
Vertical measurements on left hand side read as follows,
18, 30, 40 (to where the taper starts), the taper is 65 from the beginning of the fold to the corner edge.  The Grey part is 65 mm from top to bottom folds.
For some reason I didn't take measurements from the tapered parts, only that the bottom fold is 30mm.
Oh and it's a 3-4 mm drop to the centre tab for the bonnet latch.
#6 roxiedog
roxiedog
  • 20 posts
  • Name:terry
  • Car:LX
Posted 12 July 2014 - 06:06 PM
thanks for sharing Liam
