Easiest way to get extractors off a V8
#1 _Azza_
Posted 11 July 2006 - 04:58 PM
#2 _munro_
Posted 11 July 2006 - 05:29 PM
some extractors basicly come out with no effort others you nearly need to rip the motor out.
but if you've unbolted them and tryed removing them with no success then it's proberbly time to unbolt the engine mounts
tom
#3 _Azza_
Posted 11 July 2006 - 05:42 PM
#4 _UCV80_
Posted 11 July 2006 - 05:43 PM
i recon hoisting up the engine would be the only way. its a mega tight squeeze.
,nathan
for the dizzy, all u need is a short 9/16 ring spanner and come in from the heater box side. i sat on the engine to do it. hehe
Edited by ToranaZ, 11 July 2006 - 05:45 PM.
#5 _pallbag_
Posted 11 July 2006 - 05:50 PM
#6 _Herne_
Posted 11 July 2006 - 06:04 PM
Hahaha, you have hit on one of the many GMH shortfallsIf they stuck it on the front it would then be a Ford, heavens forbid!!
Herne
Posted 11 July 2006 - 09:16 PM
dizzy is at rear to make motor shorter.
tip; gut an old open ended spanner and put a 70 deg bend in it.
cheers.
#8 _HatchmanSS76_
Posted 11 July 2006 - 09:42 PM
You can buy a tool that is good for work on the dizzies. Comes in 3 pieces and you can plug a rachet drive into for better use I've found.
Posted 12 July 2006 - 12:23 AM
Or a Chev!If they stuck it on the front it would then be a Ford, heavens forbid!!
#10 _pallbag_
Posted 12 July 2006 - 05:09 AM
Posted 12 July 2006 - 07:44 AM
If you think that is a hard bolt to access talk to anyone with a 5 litre EFI engine with the stock Holden inlet manifold. A simple job like changing the plug leads... I was swearing and cursing for hours!
#12 _Yella SLuR_
Posted 12 July 2006 - 07:51 AM
It took me a good 2 hours of fiddling and a nylothane flexible steering link to work it out.
Posted 12 July 2006 - 07:52 AM
Guess I'm out of touch on Chev's huh????
#14 _Yella SLuR_
Posted 12 July 2006 - 07:57 AM
#15 _Yella SLuR_
Posted 12 July 2006 - 05:03 PM
#16 _Azza_
Posted 13 July 2006 - 12:06 AM
Sounds tough as though coming straight out the extractors. Im gonna record it on the laptop tomorrow
#17 _Azza_
Posted 13 July 2006 - 02:01 PM
