Reaper Customs Projects
76 replies to this topic
#1 _Viper_
_Viper_
Posted 08 May 2014 - 11:22 PM
Hey guys, I thought id show everyone what me and the boys have been getting up to at work...I'll use this one thread to show our various projects but first up is actually a Torana.
John, a fellow member on here came to us after the car had been sitting at another shop for over a year pushed into a corner :/ They had done some decent work and replaced most of the front panels but most of the gutters were rusted out as well as some issues with the fitment of the tail lights and rust in the beaver. But ill start off with the roof swap.
This is pretty much how it came to us:
Took a bunch of measurements first, like the width of the gap between the tops of the doors and the roof, bottom of the windscreens to the top, height of the side windows etc to ensure the new roof went back on in the same position... Then a bunch of temporary bracing was welded inside to keep everything in place once the top was removed:
Then out came the Air-Grinder, at this stage everything was just cut off near on as high as possible.
Unsurprisingly all the internal structure was abit rusty since its all bare metal inside from factory
Then I removed the layers of skins so there was only one layer left per pillar... All the cuts are staggered so once its welded back together all the welds are not in the same place to increase strength, next is a pic of the aforementioned pieces... all fairly rusty and were thrown in the blast cabinet and cleaned back to fresh steel (the piece in the top left of the bottom-right pic had already been blasted)
All the exposed sections on the body were blasted and cleaned and coated in epoxy inside n out.
After alot of measurements the new roof was carefully trimmed back, test fitted, trimmed abit more etc etc until I was happy with the fitment then the whole inner frame was sandblasted as well as the gutters, outer skin was already bare metal when delivered to us so just used some ranex to clean it up, Then the lot was also coated in epoxy
Once cured all the edged that were to be welded were cleaned up, weld through primer applied to areas I wont have access to later, roof was sat on the car and after many measurements while compared to the measurements taken at the start the roof was tacked in place:
Glass was also test fitted, the rear glass sat in nicely with even gaps all the way around:
But when I fit the front window frame seemed abit out of square even tho it measured up ok. You can see how the gap is tighter near the bottom (red circle) but opens up at the top (blue circle) and it was the opposite on the drivers side.
So decided to put some decent welds on the B and C pillars as I was happy with where they were and then use the port-a-power to adjust the front pillars slightly (talking a few mm)
Thats where I am up to at the moment, Will clean back all the welds, then adjust the front until im happy... tripple check everything measures up nicely, start welding in the outer layers then Lead wipe the factory joins.
#2 Ice
  • 15,221 posts
Posted 08 May 2014 - 11:41 PM
Nice work Clint you guys that do this sort of work truly amaze me
now whats with the hot rod in the corner
#3 _Viper_
_Viper_
Posted 08 May 2014 - 11:50 PM
Full Resto, Original 32 Steel body. Robs working on that one at the moment... I'll put pics up of that one soon
#4 _Bomber Watson_
Posted 09 May 2014 - 09:45 AM
Looking good.
Any particular reason you will be lead wiping the joins Clint?
Edited by Bomber Watson, 09 May 2014 - 09:47 AM.
#5 _Viper_
_Viper_
Posted 09 May 2014 - 10:30 AM
Requested by customer, cars going back to original.
Even so, personally for a join like this that is quite deep with sharp edges I prefer lead as it's abit thick for bog and sinkback is a issue
Oh and I'm just talking about the join on the outside of the c-pillar where there was lead from factory, the other joins are all butt welded and no filler required
#6 _Bomber Watson_
Posted 09 May 2014 - 12:14 PM
Fairy nough.
#7 _Viper_
_Viper_
Posted 09 May 2014 - 04:01 PM
Here is a quick little job from the other day... Domonic had fitted a RB25DET to a R31 Skyline, wasnt happy with the piping he had as the pipe between the Turbo and intercooler was hitting the power steering pump aswell as the pipe between the Intercooler and Intake was sitting on the radiator hose so I made up a new set in Stainless for him.
Before:
Attached File  Dompipesb4.jpg   93.81K   11 downloads
After:
Attached File  dompipesafter.jpg   117.88K   11 downloads
-Clint
#8 Evan
Evan
  • 1,287 posts
Posted 09 May 2014 - 10:19 PM
Amazing Clint!
Its refreshing to see someone doing a job properly.
A few months back i was purchasing some fiberglass from a reputable panel and paint shop and the first thing he said was "Are you fiber glassing over some rust?"
I will have to pop in one day.
#9 Ice
  • 15,221 posts
Posted 09 May 2014 - 10:51 PM
We might need to talk Clint about a certain project of mine
#10 LXCHEV
LXCHEV
  • 3,655 posts
  • Car:'76 LX - 383 Chev
Posted 10 May 2014 - 07:56 AM
Awesome stuff, keep the photos coming.
#11 _Viper_
_Viper_
Posted 10 May 2014 - 09:41 PM
Thanks Evan, yea we have seen some serious dodgy work on some cars that have come in... We will never be the cheapest we are not trying to compete with anyone else just try to do the best work that we can do. But yea come down any time :)
No worries Gene, im curious now ;)
More pics eh? Well while we are on the subject of pipe work here is a couple more:
This was on a Gemini with a little turbo motor. Made up a 3" Stainless dump pipe from a 90' Mandrel bend... first used the press to squish it down to the basic oval shape, then abit more hammer work just to get it inside of the flange, tacked it in place at the right angle I wanted then beat it from the inside out to match the shape of the flange... only one corner needed abit of heat to get it fitting nicely... weld it all up then sand sand and polish :)
Attached File  dump.jpg   154.29K   7 downloads
Attached File  insidedump.jpg   149.33K   6 downloads
Attached File  dumptestfit.jpg   175.46K   7 downloads
Then made the rest of the exhaust, all polished 316 stainless with V-band clamps dumping just before the diff. It sure is loud! even with the turbo.
Attached File  brodiesexhaust.jpg   24.88K   7 downloads
Attached File  brodiesexhaust2.jpg   34.55K   7 downloads
Attached File  exhaustfitted.jpg   196.93K   7 downloads
#12 _Viper_
_Viper_
Posted 10 May 2014 - 09:53 PM
This was another Gemini, this car will be running some quick times soon! (I seem to get alot of Gemini work)
Attached File  gemwrcpipes2.jpg   199.68K   8 downloads
Attached File  gemwrcpipes.jpg   116.89K   7 downloads
Attached File  Gemwrcpipesfitted.jpg   192.39K   7 downloads
This pipework was part of a RB25DET conversion into a E36 BMW I did, including a Haltech Sport 2000 install and tune, made 336rwhp and ran a 12.5 before sheering an axle at the next meet.
Attached File  coolerpipetakk.jpg   168.62K   7 downloads
Attached File  coolertotbpipe.jpg   148.16K   7 downloads
10171775_739739222725308_2138343028_n.jp
1779192_708393279193236_862949761_n.jpg?
Edited by Viper, 10 May 2014 - 09:59 PM.
#13 _mello92_
_mello92_
Posted 10 May 2014 - 09:58 PM
Very impressive, looks fantastic!
#14 _05-BROCKY-05_
_05-BROCKY-05_
Posted 12 May 2014 - 03:58 PM
Loving this thread. :clap:
#15 _Viper_
_Viper_
Posted 12 May 2014 - 10:25 PM
Well didnt get to spend much time on the Torana today but here is what I did get done.
Plug welded the rear inner roof brace to the C-pillars:
Had to make a slight adjustment to the front window frame as it was out of square and had to move it over towards the drivers side 3mm
Not having much experience with LC/LJ's myself, today I noticed their dashes are almost identical left to right... were these cars ever offered in left hand drive countries?
Anyway now I was happy with where the A-pillars were I fully welded the first join, cleaned up the welds a little and sprayed the insides with weld through primer (this stuff smells so good!)
The inner A-piller section was sandblasted, the back side sprayed with the same weld through primer and put in place.... Can never have enough clamps ;)
Weld weld weld, grind grind grind... still abit more grinding to do but ran out of time.
Next time ill finish cleaning it up, then fit the outer skin section then ditto on the drivers side :)
#16 MictheAussie
MictheAussie
  • 236 posts
  • Name:Mic
  • Car:LJ
Posted 13 May 2014 - 11:51 AM
LJs went to somewhere in Asia as a LHD Chevrolet.
#17 355LX
355LX
    Long Term Project
  • 611 posts
  • Car:LX hatch
Posted 13 May 2014 - 03:40 PM
Great work Clint! What brand of weld through primer are you using?
#18 _Viper_
_Viper_
Posted 13 May 2014 - 08:30 PM
U-pol weld through primer #2 it's in a green aerosol can, tried a few others and this is the best so far.
#19 rodomo
  • 18,063 posts
Posted 13 May 2014 - 08:50 PM
Looks like it's full of copper?
#20 _Viper_
_Viper_
Posted 14 May 2014 - 12:11 AM
http://www.u-pol.co....ELD2-TDS-EN.pdf
#21 _Viper_
_Viper_
Posted 14 May 2014 - 09:52 PM
I'll start off with a quick job I did this morning, Fella came in for a service... was chatting about the car and ended up adjusting the front Torsion bars and fitting 3" lowering blocks to the rear
10325344_10152141275953391_6496568550595
Back to the Torana, Did the same on the inside of the Drivers side A-piller:
1DriversApillerinternalwelded_zpse10ec67
Next was the outer section of the passenger side A pillar
2passengerouterApillerweldthru_zps8e5596
3passengerouterApillerclamped_zps505816e
4passengerouterApillerground_zps17d21f07
Ditto on the drivers side:
5dribersouterApillerground_zps38fb5c2f.j
Finished off the B-pillers up to this stage:
Next what the Inner C-pillar sections, they were blasted and sprayed with weld through primer on the inside:
Ditto on the C piller
Then tacked in place... and thats where Im up to atm... Will fully weld this, same for the drivers side. The 2 gutter sections on the C-piller need re-instating then all these sections will get sandblasted and sprayed in epoxy.
Here's a oddball one for you, Came in yesterday... Old fella passed away and left it to his son... Needs to pass the yearly hot rod inspection so we are just getting it up to scratch, replacing bushes, cracked hoses, wiring etc... 34 Ford Rat
Then had a welcome surprise visit from an old customer, we Resprayed his 2005 Ford GT a year or so ago... hes just finished getting it all together so payed us a visit and booked it in for the final de-nib and buff and a run on the Dyno! Should be about 600rwhp
Owner on the left, Cam my business partner in the middle and our panel beater Rob on the right.
Shame the sun wasnt out, Will have more pics of this after we do the polish but you can see pics from when we sprayed it here:
https://www.facebook...78198932&type=3
#22 rodomo
  • 18,063 posts
Posted 14 May 2014 - 11:31 PM
Did you do a front end alignment after the torsion bar adjustment?
#23 dattoman
Posted 14 May 2014 - 11:59 PM
And fit shorter shocks ?
#24 _Viper_
_Viper_
Posted 15 May 2014 - 12:27 AM
We personally didn't no (is that what you meant?) altho I wish we did, we don't have every tool yet. We send our customers cars to Pedders down the road.
Interesting? why would you need shorter shocks, The car is not hitting bump stops, are the standard shocks not designed to be able to reach the bump stops?
#25 _mick74lh_
_mick74lh_
Posted 15 May 2014 - 10:39 PM
I'd be interested to know that too. I just thought that shorter shocks were only needed with coil springs so that shorter springs are still held captive at all times?
Nice work you're doing though Clint. Some of that pipe work is amazing!
