Spider Gears are needed, and a Gear change while there,
so we either have spare parts, or a Goodie Exchange job.
Now that is the other option, a Fully Reconditioned Centre
Posted 20 June 2014 - 11:06 PM
Posted 20 June 2014 - 11:22 PM
How is going to a 3.55 or 3.7 going to widen the gap between 1st and 2nd though ? As has been mentioned you need a taller diff or even a different box for that.
Its not.
When i was driving my mates LH around with a supercharged 304, t5 and 3.9's the best way to drive it calmly was go 1-3-5.
Totally skip 2 and 4.
Then when you were under it go through all the gears.
Short of changing the box your not going to fix that issue.
Posted 20 June 2014 - 11:29 PM
I agree DJ,
how do we have the best of both worlds,
have a 5 or 6 speed box and have spaces between gears.
a compromise or less gears or a taller diff?
Edit:-
When you have the Power in the Motor,
to me, a 3 speed gives the gear spacing, and the 2.78:1 diff gives the overdrive.
Edited by TAXIPOWER, 20 June 2014 - 11:38 PM.
Posted 21 June 2014 - 05:09 AM
Not sure of the condition of the Cones or housing spider gear shaft supports yet,
we will have to wait a bit there,
I want to change out rear ends last weekend, and now this weekend,
but it is a bit of a job, as you can Imagine I got to get to work on Monday.
Might have to bite the bullet.
is your one an LSD Tony?
Posted 21 June 2014 - 07:28 AM
You need to verify which 10 bolt diff you have. You mention that it is a "cut down hk Bathurst 10 bolt diff with 3.08 gears" which I believe are Chev 10 bolt diffs, not the Large Salisbury Holden 10 bolt that was fitted to the V8's & 1 tonner etc. range. As far as I'm aware none of the parts are interchangeable.
Chev 10 Bolt.
Chev 10 Bolt.jpg 23.62K 1 downloads
Holden/Sasibury 10 Bolt
Holden 10 bolt.preview.JPG 72.55K 1 downloads
Edited by warrenm, 21 June 2014 - 07:42 AM.
Posted 21 June 2014 - 10:33 AM
Posted 21 June 2014 - 05:35 PM
so what does this eBay ad mean:-
Has both types mentioned?
http://www.ebay.com....34ddc864&_uhb=1
Posted 21 June 2014 - 07:03 PM
Posted 22 June 2014 - 09:56 AM
You could give Chris' differentials a call. If he cant help you he might know someone who can.
https://www.facebook...?type=1
Posted 22 June 2014 - 01:24 PM
Posted 22 June 2014 - 01:35 PM
I realize this is V8 Stuff,
but, for example, a M22 from a 1 Tonner Red Six has a 1st Gear Ratio of 3.74:1, which when coupled with a 2.78:1 Ratio Diff equates,
to a M20 1st gear and a Diff ratio of about 3.4:1. ( and that is the 1st gear take off )
I just had to drop that Idea in.
Posted 22 June 2014 - 07:38 PM
