My LJ GTR Torana on the rego papers has a TARE weight of 900, have it on two other things from ACT RTA that say 900 TARE weight, seems very light or is that correct for a 1972 LJ GTR Torana ??????
AL
Posted 13 July 2014 - 01:18 PM
AL
Posted 13 July 2014 - 01:32 PM
Bit of a discussion here Al:-
http://www.gmh-toran...lj-tare-weight/
I have seen weights for little 6 cyl Torana's ranging between 925kg through to 1100kg,
Every Torana would be different, as you have all sorts of options and their weights,
so the Rego mobs would have the average weight listed and your one is at least 100kg under weight.
Rego papers typically list one of the lighter vehicles in the model range.
"Holden Torana Performance Handbook" lists the LJ GTR at 2334 lb (1058 kg) and the XU-1 at 2417 lb ( 1096 kg)
"60 years of Holden" lists the LJ GTR at 2334 lbs (1060 kg) and the XU-1 at 2417 lb (1096 kg)
Posted 13 July 2014 - 01:39 PM
Thanks for that, so my LJ GTR is lighter than the normal LJ GTR going off the ACT RTA Tare weight, very interesting.
AL
Posted 13 July 2014 - 08:22 PM
The weight on your rego is just an arbitrary weight used in by VIC rego, it has nothing to do with the actual weight of your car.
The tare weights published by GMH are estimated weights.
Posted 13 July 2014 - 08:30 PM
Al
It was probably weighed in between engine changes!
Posted 13 July 2014 - 10:28 PM
Its on the ACT rego papers for the car, not from Victoria, unless ACT made a mistake on the TARE weight of 900
Posted 13 July 2014 - 10:37 PM
ACT rego papers, 900 TARE weight on rego papers ??????
Posted 13 July 2014 - 10:38 PM
Al, I wouldn't place too much importance on the TARE weight listed on the rego papers. Possibly a default weight they use when they don't know the actual weight of the vehicle.
Posted 13 July 2014 - 10:41 PM
Yeah Dave
I thought what was going on with the 900 Tare weight
Posted 13 July 2014 - 11:12 PM
Hey Al,
I found my LC GTR Rego paper from 1984,
and it is called a Sedan, and the Tare weight is 1040kg, very strange.
Posted 13 July 2014 - 11:17 PM
Yeah for sure, the weight is strange on the rego papers, I got a history check from ACT RTA and on that report from them it says 900 TARE weight.
GMH called the 2-Door a Sedan on there ADR Plate
AL
Posted 13 July 2014 - 11:22 PM
I guess any Canberra members that have rego there car in the ACT, would know how they do there TARE weight, as in the RTA there weigh the car etc, so they know the weight for your car, or do they use a guide in a book at the RTA there, any ACT members know ??
Posted 14 July 2014 - 06:54 AM
Hey Al,
It IS a sedan, LJs only came as either a 2-door sedan or a 4-door sedan. There was a prototype 2-door LC coupe, bit it did not make production.
Also the 1040 kg tare is probably about right. To my knowledge all the 'weights' listed by GM-H are kerb weights not tare weights. The difference is the mount of fluids on board. I believe kerb weight is measured with the fuel tank full & tare has the tank half full.
Dr Terry
Posted 14 July 2014 - 08:09 AM
Dr Terry
Dr Terry, GMH list the 'shipping weight' for the LJ series. Shipping weight is vehicle without oils and water.
Posted 14 July 2014 - 10:08 AM
Thank-you Al, Dr Terry and Spack
Posted 14 July 2014 - 11:19 AM
My QLD Transport rego certificates list my LJ's TARE weight as 1.02 Tonne.
Posted 14 July 2014 - 01:47 PM
Good Man Dave,
20kg different to NSW, and 120kg different to ACT, hmm
my Rego Weight, was from Newcastle NSW
we are getting a list going, and I wonder how much difference this makes the rego cost
Posted 14 July 2014 - 07:36 PM
In QLD, no difference whatsoever for a passenger vehicle.
Posted 07 September 2014 - 10:00 PM
Posted 08 September 2014 - 12:02 PM
Posted 08 September 2014 - 12:27 PM
Pretty much ^
LC/LJ 6 cylinder Torana is the same cost to rego as a 80 series Landcruiser/GQ Patrol....
Posted 08 September 2014 - 02:08 PM
Posted 08 September 2014 - 02:39 PM
Lol, yeah, ute levy, my Hilux is more expensive to register than my old 80 series...Go frOcking figure.
Posted 08 September 2014 - 07:08 PM
Dr Terry
when i had to register my car last year we needed to find the RTA code in order to get the specifications. tare weight for my car was 1070. FYI
it's on my rego papers
