Gday all
in my uc hatch here i have a 202 bored out to 208. It has a 60/40 cam and is running high compression, but on standard head, extractors and electronic ignition.
Now ive tried over and over to get the car to idle, and it will just hold on at 1400rpm. IN saying that the 350 holley needed a rebuild hence ive ripped it off started pulling it apart. Im am pretty sure the jet sizes in it atm are bigger than needed as the motor before i purchased the car had a yella terra head.
One of my questions is, what type of jet sizes would i be after? I dont intend on changin the head anytime soon.
second question is, would i be better off with my current set up using a ww for the time being?
Dale
350holley on 208
_doucmyuc_
, Jul 15 2006 04:18 PM
3 replies to this topic
#1 _doucmyuc_
Posted 15 July 2006 - 04:18 PM
#2 _Keithy's_UC_
Posted 15 July 2006 - 05:15 PM
I had this problem with mine too.
Check your choke gear is connected how it should be (i had mine connected but did not use it). Otherwise your butterflies will not open properly, and your air fuel ratio will be incorrect. Mine wouldnt go below about 1300rpm until i fixed this problem.
With my choke gear, i have a piece of steel wire from the butterfly to the other thingy holding it shut.
Keith
P.S. "Other thingy" is the technical term too!!
Keith
#3 _Sammy_
Posted 15 July 2006 - 09:48 PM
you may need jets anywhere from 50-60 .... its hard to narrow it more than that though without some trial and error tuning.
#4 _doucmyuc_
Posted 16 July 2006 - 08:00 PM
thanx for the help guys
Keith: Iv epulled apart the choke linkage assembly and cleaned it etc, but it still seems to be very bloody sticky on that stupid lock pin. Have you got pictures of how you set the choke up?
Dale
Dale
