Speedo adjustment...changing wheel sizes
#1 _trav_
Posted 16 July 2006 - 10:23 AM
Im in Melbourne..prepared to take a drive...Im just wondering if anyone here knows anyone that can adjust my speedo as i am changing my wheels from 13 inch to 14 inch?
Trav
#2 _Flamenco_
Posted 16 July 2006 - 01:29 PM
#3 _trav_
Posted 16 July 2006 - 01:47 PM
trav
Posted 16 July 2006 - 01:57 PM
Be ready to tell them new tyre size, diff ratio, gerbox etc.....
#5 _Keithy's_UC_
Posted 16 July 2006 - 04:54 PM
Keith
Posted 16 July 2006 - 07:58 PM
Liek if you go from 205/60.13's or something, to low profile 15; you may find the speedo isnt out to much at all!
#7 _devilsadvocate_
Posted 16 July 2006 - 08:07 PM
No its not hard to get to the gear, just trace the speedo cable to the box and the gear is right on the end of the cable, youll have to unbolt it. The actual gear for the trimatics and aussie boxes is easy to replace, not so easy for a mc6...is hard to get to the gear??
You havent mentioned what gearbox/diff you have, it may well be that you have the tallest speedo drive in there already, in which case there may not be a speedo gear to match your increase in tyre size.
Re whether there is an increase in size or not?:
Go to http://www.powerdog.com/tiresize.cgi to check you intended tyre size diameter against that of the standard wheel size for your car, if its LH_UC closest would be 185/75/13.
Edited by devilsadvocate, 16 July 2006 - 08:10 PM.
#8 _trav_
Posted 17 July 2006 - 11:12 AM
The tyres on it currently are 205/60R13...i don't know tyres that well so if i wanted to put a low profile tyre on a 14 inch rim what size would i be looking at?
trav
Edited by trav, 17 July 2006 - 11:17 AM.
#9 _trav_
Posted 17 July 2006 - 11:21 AM
trav
#10 _devilsadvocate_
Posted 17 July 2006 - 11:38 AM
What width rims do you intend running and what performance/look are you after. If 14 x6, a 205/60 would basically give you much the same look as the 205/60/13.The tyres on it currently are 205/60R13...i don't know tyres that well so if i wanted to put a low profile tyre on a 14 inch rim what size would i be looking at?
trav
Im sure others will have lots of suggestions here.
Edited by devilsadvocate, 17 July 2006 - 11:39 AM.
#11 _trav_
Posted 17 July 2006 - 11:43 AM
trav
Posted 17 July 2006 - 02:14 PM
A 205/55/14 will have a similar rolling diameter to a 205/60/13.
Grant..
