hey guys, in the near future im going to upgrade my carb, i currently run a standard BX carb which has a annoying flat spot, its on my 186 which runs a mild cam, and extractors.
I want to know what fuel comsumption a set of tripples would use? and how much more power would i gain/lose.
OR what would a Holley 350 or similar run like?.
I feel like the carb i am running is not giving enough power. it has been re-jetted not long ago too.
carby questions
_hrt1and2_
, Jul 17 2006 03:10 PM
3 replies to this topic
#1 _hrt1and2_
Posted 17 July 2006 - 03:10 PM
Posted 17 July 2006 - 03:44 PM
A Holley 4bbl with Vacuum secondaries like a 390, would be a perfect choice. It runs at about 270 with the secondaries closed and gives you instant response.
Economy depends on the weight of your right foot.
A set of triples (Strommies/SUs/Webers/Dellortos/etc) is not a choice for fuel economy. Power gains are appreciable and responsiveness, when tuned well, is amazing. It should be noted that the engine should be adjusted to suit triples, otherwise it's restrictions will rob the overall usefullness of the carbs.
Grant..
Grant..
#3 _hrt1and2_
Posted 17 July 2006 - 09:18 PM
do u know what price a 4bbl 390 would go for?
Posted 18 July 2006 - 07:44 AM
2 on e-bay at the moment. The are both mechanical secondary and are off nascars.
http://cgi.ebay.com....1QQcmdZViewItem
There have been others cheaper but usually around $200ish. Few and far between.
Not a common size.
Not a common size.
