Bolting manifold on to holden 6
1 reply to this topic
#1 LC-069
LC-069
  • 363 posts
  • Name:Mark
  • Car:LC GTR & LX SL
Posted 22 July 2006 - 03:03 PM
Just installing my triples on to my holden 6 9 port head. Its a warnerfold manifold and pacemaker extrators. The problem is that the standard manifold square blocks are hitting and do not clear the manifold/exhaust.
Are there special types to buy or should i start grinding away?
Anyone experience this before?
#2 gtrboyy
gtrboyy
  • 3,142 posts
Posted 22 July 2006 - 08:46 PM
On my 202 I had the cain triple webber manifold & genie extractors.I had clearance issues as well so I screwed in more studs,fit manifolds & then had to grind down the spacers untill it all fit.
I also ended up using those 2mm thick inlet gaskets from supercheap as mine kept swallowing gaskits.It was either the fact that I couldn't tighten the manifolds enough or the thinner gaskets didn't like 7000rpm.
